I made an Anvil
发表于 2021-9-1 23:16:05 | 显示全部楼层 |阅读模式
Tried to buy an anvil but not happening!   At my customers Mine site I saw a defective impact hammer from a rock crusher, 4 of these are installed on a rotor and it spins super fast.   Any way I cut it in two  pieces and welded together using rods from Lincoln for Hadfieldmagenses.   I cut this using a Carbon arc gouging torch.  The holes I drilled with concrete bits on my Enco mill/drill, I probably used at least a 100 bucks worth of drill bits and took all day.  The Anvil weighs #340 lbs and the Florida oak stump at least 100 lbs.
It seemed like a good idea at the time!
Reply:That's nice work. Most of that crusher stuff is high Manganese and will work harden well from impact.
Reply:that is huge.  Looks like a real anvil to me.  Good job.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Reply:Wow.  Great job on the anvil. Very impressive !
Sent from my iPhone using Tapatalk
Reply:Very Nice.Any pictures when you were cutting it or forming the horn?sounds like a tough job.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Yep... I bet you added some new words to the Dictionary making that Hardy too. Nice work.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:Very nice work!  I've wanted to do something similar for ages, but I don't think I could make an anvil that nice!How'd you turn the horn all nice and conical like that?  Was the steel hard to grind?
Reply:To answer the earlier questions about the horn and the hardy hole.  I shaped the horn with a carbon arc gouging torch and the a 7" grinder and yeah its hard!   The hardy hole I drilled the 4 corners with a 1/4" bit and the finnnaly a 1" bit in the center and cleaned it up with a carbide bur. I have about 100 hours in it!   seems crazy and  really freaked out some old timers when I told them what I was doing at my industrial park.It seemed like a good idea at the time!
Reply:Very impressive indeed and it has a patent!
Being manganese steel I'd guess preheat would be a no no or preheat and/or welding would have to be kept under about 500 deg's.?
Reply:That is truly Impressive! Very clean shaping on the horn. I would not have guessed it was done with a handheld grinder.
Reply:I did pre heat it, that was a trip. basically made a ring about 30" filled it with Kingsford briquets put the 2 pieces in there and covers with another bag and let it preheat.  Every bead I ran had to be peened with an pneumatic impact, just as soon as the slag peeled off.  If I didn't peen it it would crack almost immediately.  I made this in 2012 and looks so cool in the shop!It seemed like a good idea at the time!
Reply:What are it’s dimensions?Sent from my iPad using Tapatalk:
Reply:I’ll give you 100 bucks for it…
That looks like it was a lot of work…should serve you well for years…
Reply:Really nice job on the anvil.Manganese doesn't work harden, it work toughens.
Reply:It's 25 1/2" long, 5" wide by 13" tall and weighs about 340 lbs.It seemed like a good idea at the time!
Reply:That is extremely well crafted!  My hat's off to you sir.Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Reply:welding1, you are like a chainsaw artist except you sculpt with a carbon arc gouging torch
Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
GMT+8, 2025-12-19 19:23 , Processed in 0.104830 second(s), 18 queries .
