18 to 20 Volt adapter for DeWalt
发表于 2021-9-1 23:16:05 | 显示全部楼层 |阅读模式
I had an 18 volt drill kicking around that had less than stellar battery performance when new, and went downhill rapidly as the batteries got older. I've quit buying anything 18 volt in favor of 20's, and it was a gift from the kids so I didn't want to just toss it. New batteries just for one tool didn't seem to make sense so I was watching the adapters come on sale. Mostly what I was seeing was 2 small batteries ( I didn't want) with another charger ( I didn't need) and an adapter coming on sale for $170 Cdn. Didn't make much sense when you could replace the drill with a 20 volt for $130. I started looking on Amazon.Ca and found a bare adapter (no batteries, no charger) from an independent manufacturer for $25 Cdn. I got it this week and it works great. Product reviews say it is easier to handle than the DeWalt version. My 4 and 5 AH batteries make the old 18 volt work like a new drill again. I was using it yesterday with a rotary wire brush for cleaning up welding slag and it performed like a trooper. The adapter comes from Biswaye (model DCA 1820 ) but is unfortunately currently unavailable at Amazon.Ca.... didn't check the American page.  Good thing I bought it when I did.  https://www.amazon.ca/gp/product/B07...?ie=UTF8&psc=1
Last edited by whtbaron; 01-16-2021 at 08:40 PM.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:The older 18 volt 3/8 drill is a slightly larger body than the newer 20 volt 1/2", but you can see that the adapter is fairly compact and doesn't add a lot of bulk to the unit. You cannot use the adapter for charging, the 20 volt batteries get charged on the 20 volt chargers as expected. Looks like I won't be needing that old 18 volt charger anymore...250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:dewalt makes an adapter and ebay has them as well $25 for 2.
Reply:I had one for a grinder.  It seemed to never would maintain charge after sitting. Got mine from and returned it to home depot.
Reply:Error!..........Last edited by John T; 01-17-2021 at 07:57 AM.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
That would be $US and yes, I'm sure lots of American members will find better pricing, but many won't ship into Canada. What I'm finding up here is closer to $45 to $50 Cdn. for a single adapter from DeWalt. "I had one for a grinder. It seemed to never would maintain charge after sitting. Got mine from and returned it to home depot."There are cheaper versions, but I went with this one because it seemed to have good reviews. A cheaper model had some complaints about contacts melting off under high load tools. I notice that they have added the caveat not to store batteries in them, so maybe more people have had the same issue as you. So far mine has just sat overnight between uses so I haven't tried to store it connected for an extended period.
Reply:Ahhh.  Mine was Dewalt brand.  Probably should have read directions, it may have stated necessity for battery removal...  Another issue, the Dewalt kit came with batteries and the size battery was not appropriate for the grinders.  The old grinder was too inefficient.
Reply:the genuine dewalt adapters have electronics so you can run the 20volt battery down to nothing in an 18 volt tool, but use battery power so you need to remove the batter from the adapter or over time the battery will drain...the after market adapters dont have any electronics, so use the 20 volt down to 1 bar and recharge and no damage to the battery...and the adapter doesnt use any battery power..the off brands work great...and are half the price of the dewalts...
Originally Posted by ronsii
LOL!!!  I could see where some of the import ones would have issues with the contact melting!!! I am not sure what they use but even some of the knockoff batts have questionable tabs in them for the contact points
I know it isn't copper or even steel with copper cladding
I haven't tried the knockoff batteries, but I've been told they don't last like the DeWalts so I might skip those. One of the bad reviews on the cheaper adapter suggested that the contacts had been soldered instead of silver soldered so they came undone when heated up. Not sure about the details, but it shouldn't be a big deal to come up with better connections if necessary. So far this one seems good, but the only 18 volt tool I have to run it in is the 3/8 drill.
GMT+8, 2025-12-19 19:25 , Processed in 0.070439 second(s), 18 queries .
