60 INCH Mechanical Shear
发表于 2021-9-1 23:16:03 | 显示全部楼层 |阅读模式
Here’s something I just had to share.  Due to nothing but sheer luck, this morning I was able to save this electric shear from the scrappers. It hadn’t been used in years and a local marine fabrication shop needed the space,  pushed it outside and scheduled the scrap truck to pick up the next day. So ... $300 CA dollars later ($224.28 usd) and under an hour round trip, I had it home. Nice overall shape for a 48 year old Made in China machine.  Blade has no nicks but needs sharpening. 60 inch width of cut.3/16” aluminum, 1/8” SS capacity 5500 pounds 3 HP 3 phase
Reply:great deal. congrats.
Reply:I like the "no cutting flat bar" sign... must be for that guy who uses wiss snips to cut wire.
Reply:Congrats Terry. Do the blades flip over? At least on my stomp shear, they flip over so it may be that yours can flip over and that side may be in good shape or better shape.Millermatic 252 MIGMiller Dynasty 200DX TIGMiller Spectrum 625 PlasmaAltas 12x36 Metal LatheBridgeport Milling Machinewww.psacustomcreations.com
Reply:Nice score!
Originally Posted by walker
Nice score!
Reply:Really nice score
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Looks like your first project is making a belt guard. Do you know if there are any problems with it?
Reply:The foreman said the shear was in working order but “in need of maintenance” and it sat unused because the owner was too cheap to address it. I’m quite certain they had a bigger newer one in their shop. It came with the belt guard. Doesn’t even require body work.
Reply:get your story straight for when the cops show up. that was a steal!i.u.o.e. # 15queens, ny and sunny fla
Reply:Heh heh. They loaded it for me too. I didn’t even have to drop my forklift off the truck.
Reply:So sweet! Congratulations on the steel of the year!
Reply:Thanks  V.   I’m kind of embarrassed though. I just had a thought and double checked.  When I first unloaded it, I measured the bed width which is 60” but the width of cut is actually 52”.
Reply:Well that's it, haul it off for scrap.
Originally Posted by Lis2323
Too traumatic. The poor shear was saved from the scrapper just last week.  I’m getting soft in my old age.  It can stay....
Originally Posted by ronsii
You know.... they have pills for that
LOL!!!!
Yours are BLUE, right ??
In that case, I will give you $350 in Canadian for it since it didn't live up to its advertising. You make a quick profit of $50 and clear up space for a real 60" machine.
Reply:I might not get around to setting up the shear until the winter but I thought I should take advantage of the good weather to degrease and wash the underside.
I scoured the surface rust off a spot on the blade and it is indeed flippable. There is at least one good edge available for sure so that is good news. With a little bit of luck it will only require cleaning and set up.
:Good score.  Just be mindful that it is not hydraulic and once you engage the clutch it will follow through its stroke until it returns up.  Think before you press down because you can't stop it mid stroke.
Thanks for pointing that out although I am quite familiar with the concept,  (I have a Pendinghaus 60 ton mechanical iron worker) these machines have to be treated with respect.
It's so pretty!!!!  I don't even mind that it's yellow
but that red leg
Reply:So yesterday I answered an ad for a fellow looking for a mig gas bottle.  Today I sold him this full 330 cu ft bottle of C25 which MORE than paid for the shear. Some days just seem to go so smooth.....
Edit. Oops forgot the pic And my point being I got a good deal on the shear —- I did NOT overcharge for the bottle.
Reply:What don't you have? Peddinghaus is top of the line in mechanical iron workers and yours look mint! My first welding job at a tank shop they had a 105 ton Peddinghaus 210 Super 20. It was the cats meow but no stopping once you push the pedal or press the button for the punch. I liked the punch because you could lower it onto your center punch mark.
He doesn't have a charcoal forge...
Reply:Yet! I used a 120 ton Kingsland hyd. ironworker and in order to line up the center punch mark you had to put it in jog mode and then switch it back to punch mode. Kind of annoying. Most of the guys tried to lift the plate up to the punch mark instead playing with the switch.
Reply:On the Peddinghaus, you pulled the handle forward and the punch would lower and you could lift the punch up and down to line it up. Then you pushed the button on the end and it punched the hole. Once you release the handle to lower the punch, the only way to reset in the up position is to push the button to punch. Never have to lift anything. Punched a lot of rectangular manways for tanks with it.
Reply:With a few modifications a can of SPAM should fit but I doubt it would slice to your obvious high standards.  Sent from my iPhone using Tapatalk:
I almost writ up a similar post
but just hit the triangle instead...  should have done the post thing instead
Triangle?Sent from my iPad using Tapatalk
Reply:Huh.  I don't even have a DISLIKE option.
Reply:Nice score!Miller Trailblazer Pro 350DMiller Suitcase MIGMiller Spectrum 2050Miller Syncrowave 250DXLincoln 210MP
Originally Posted by scsmith42
Nice score!
Reply:Nice job.
Originally Posted by Maxwel
Nice job! May I ask if we want to make repairs to the apartment. To do this, we ordered a design from a good company [SPAM LINK REMOVED] and in order to finish, we need to find a person who has mechanical shear. It is possible for a private person or company to help us with the completion of the repair. We pay in cash, just the furniture has already been brought and the repair is not yet finished and the furniture is just standing idle. And I want to ask if Mechanical Shear are suitable for cutting logs for making a fence, I am not an expert and I do not know what size you can make a fence. Tell me what the minimum and maximum sizes are, you can roughly tell how large they will be.
GMT+8, 2025-12-19 19:25 , Processed in 0.099560 second(s), 18 queries .
