Which welder is better
发表于 2021-9-1 23:16:03 | 显示全部楼层 |阅读模式
Which welder would be better to for 120v century mig welder pow'rmate 100 or Lincoln electric mig welder pack 3200 HD I know y they are both made from the same company I just need to know which is better......Thank You.
Reply:Those 120 volt machines are only for thin metal 1/8'' is about it for a unexperienced person. Save and get a 110/220 volt machine . The Hobart is unsale and is definitely a upgrade from a 110 volt machine. Buy once and your done. https://www.farmandfleet.com/product...a-dfa67146d41dCheck craigslist or facebook marketplace for a 110 volt machine. I always see them because sellers realize they need a larger machine.
Reply:im always suspicious of the 1 post wonders that ask for welders to be compared with no back ground info or any other info at that..buy them both and compare them yourself...
Reply:my welders are the bestCharl
Originally Posted by MinnesotaDave
Incorrect - mine are better and can beat up yours.
Originally Posted by koenbro
Akshally, my big brother’s welders can beat up all your welderzSent from my iPhone using Tapatalk
Reply:Hobbytime you must be the jackass snob of this welding website and for the rest of you thank you for the feedback it helped, I ended up buying Forney 271 easy weld 140mp invertor mig, flux, tig, stick welder, I bought this welder for build bridges, sky scrappers for my Town,....back to reality I bought it for auto repair to restore my 87 Jeep Wrangler YJ to repair the back frame around the rear shackle area and do some body, and fender rust repairs, in March of this year I paid a professional auto welder repair rear frame shackle area I bought the new frame repair section for $189.00 gave it to the welder left my Jeep there for 4days then went to go pickup up my Jeep he handed me the bill for $975.00 my jaw dropped I thought it would have been under $500.00 all he had to do was cut the rust of bottom of frame and shackle area to remove all the rust and then reposition the new one peace frame section to be welded I just don't understand why 4 days and the welds they weren't clean kind of sloppy that why I wanted info on 120 volt welder that's what I have in my garage so I can do my passenger side rear shackle welding repair myself and save me alot of money to invest in buying more part to restore my Jeep Wrangler instead of given ton of my money to someone else.
Reply:Two little kids in the schoolyard were bragging.1: "My Daddy can beat up your Daddy!"2: "So what? My Mommy can beat up both of them at once."An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:Lincoln hands downI would buy Lincoln if lower in cost. I also like Hobart and Miller welders too. Dave
Reply:Scratch thatLast edited by tapwelder; 08-01-2020 at 12:15 PM.
Reply:in my opinion, stick with a variable wire and voltage machine of the big three or the harbor freight mig.  just my input.  variable you can dial in sweet spot on practice metal and then weld.lincoln 125spmonkey wards 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dof course duramax diesel
GMT+8, 2025-12-19 19:21 , Processed in 0.095377 second(s), 18 queries .
