7’’/9’’ grinder, Milwaukee or dewalt?
发表于 2021-9-1 23:16:01 | 显示全部楼层 |阅读模式
Im needing to buy a new 7’’/9’’ grinder, Milwaukee or dewalt?
Reply:This is my 7-9” Milwaukee
I bought a new 7-9” Makita.
Sent from my iPad using Tapatalk
Reply:I have the 7" Makita.  Don't like it...a 4.5" grinder takes material down faster...I'll have to check RPM for each brand and see if that's a common deal.  Irritating.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I have a couple of Dewalt but most of mine are Metabo.  I prefer Metabo for sure, they seem to last forever.  Don't have any Milwaukee so can't say on them.Lincoln 350MPMillermatic 350PSyncrowave 2501969 SA200HTP Invertig 221
Reply:I would go with a 6" myself. Much better power to weight ratio than a 7".
Originally Posted by 12V71
I get 7" discs from Pearl? (I gotta check tomorrow) Man those things cut fast, I use 'em up to the very end on a 4.5" grinder. They actually shave material rather than just making small sparks.
Originally Posted by ronsii
I should look into some of those, I don't use them that often... but when you need em'... you need em'!!! at the time I just grabbed a dozen of whatever the house brand HD sells over here.. I think they're blue and silver....Hmmmm.... might be remembering wrong as we tend to buy most of that kind of stuff from HD... but it could have been from lowes...
hey... it was over a year or two ago
Reply:You know... one thing I haven't found at HD is 9 inch cutoffs....
Don't tell any body, but I save used 14" cutoff wheels for that.
Reply:I'd look for used old Milwaukees. My first one is still going and its 30 years old. This is before the mostly plastic body models.I frequently see them for $75.00Metabo has 6" and 7" grinders. I like my 4 and 1/2" and 5" ones.If you go New Milwaukee, I'd get the this one with more metal body, old-style. https://smile.amazon.com/Milwaukee-6...618277&sr=8-17Sent from my iPhone using Tapatalk
Reply:Metabo or Walter (made by Metabo) have a slip clutch but are top of the line HD if you want something for heavy grinding. Personally I'd look at a 6" as it's lighter and less fatiguing to use for extended periods. Brand of grinding wheels can make a huge difference too.
I was on a job that needed another inch of cutting depth than the 5 inch dewongs were getting me so ran to homedepot and grabbed a 7 inch makita.... got in the lift went up 35 feet and started cutting... Hmmmm this thing is only going a quarter inch deeper than my 5 inchers.... what gives????
  stupid 7 inchers lose another inch because of the bigger center
and the 7 inch makita didn't seem to cut any better than the 5 inchers with 5 inch cutoffs on them either....My solution: yank the guards off the dewalts and slap on the 7 inch discs
  worked great!!!!  just have to be careful when you set them down if they're still spinning
oh!!! and they have a little bit of precession
Reply:The soft start feature is something I would consider. The Eastwood Contour CST Burnishing tool I recently purchased has it , I like it. Sent from my iPhone using Tapatalk
I looked up grinder specs, turns out the 7"/9" grinders are RPM matched for the 9" at 6000 rpm.  So that's why mine is so unimpressive with 7" discs...I found the Dewalt 7" is listed at 8500 rpm.  The 7"/9" is 6000 rpm and says "optimal rpm for 9" discs."So @Millwrightdude, you may want to look at it like buying a 7" or a 9" because of the rpm matching.
I have a craftsman 9" with soft start (it was $70 on closeout).  First time I hit the trigger I thought it was broken
(didn't know it had that feature)Kind of nice really.
Reply:I think the Metabo 9" are 6600 RPM. Some of the smaller grinders are variable speed and have anti-vibration handles.
Reply:I bought a Dewalt (DWE4557)Im needing to buy a new 7’’/9’’ grinder, Milwaukee or dewalt?
GMT+8, 2025-12-19 19:23 , Processed in 0.068421 second(s), 18 queries .
