My Shop and a Request for TIG Recommendation
发表于 2021-9-1 23:15:54 | 显示全部楼层 |阅读模式
Hi all.BackgroundI'm 52 and live in CT.  I do cyber security work for a living and have always maintained my home, cars, and motorcycles so I enjoy working with my hands.  Welding and metal work was always on my todo list and 2 years ago I did something about it.  I took three college welding classes at a local community college that had a recent infusion of state grant money.  Suffice to say, I learned how to weld and learned how to use all of the shop equipment - presses, torches, presses, etc.  I spent most of my time stick welding in all the positions, but also spent some time on MIG and TIG.  My GearMy current house has only 100 AMP service.  I've looked into an upgrade but based on underground wiring and how it enters the house, it has been cost-prohibitive.  Based on that I bought an engine-driven welder and attachments.  That has enabled me to practice the various processes, though before last weekend, it had been about 8 months since I touched any of it. Here is what I have:Thermal-Arc TA-10/270-HE.  This is a DC CC/CV machine.Tweco stinger50' cablesMiller S-32P MIG suitcase setup for gas and .035 wire with a Bernard 300 AMP gunCK 17 FX TIG torch with gas valveSSC C810 14-pin TIG foot pedalHobart Handler 135 110v machine setup for .035 wire.  With this setup I generally run 7018 rods for ARC welding.  I use the suitcase on CV for most MIG stuff I do unless it's thin metal and I use the Hobart just because its quicker to setup and use since it's 110v.  Besides flash, the screen also provides wind protection at my garage door.The TIG setup is fairly new, so I spent some time last weekend playing around with the lift start, machine settings, etc.  I finally got it to a point where I could make puddles.Attachment 1713184TIG RecommendationWith my current setup I can pretty much weld anything.  The problem is that welding time involves running the engine, which gets a little old sometime.  Winters also suck since my garage isn't heated, though I can get it fairly warm with portable heat.  I'm also considering a propane heater.  My garage is adjacent to my kitchen.  My stove is adjacent to the dividing wall and has a 3 prong plug with double tapped 40 AMP fuses in the panel.  I was thinking I could have another run from the panel to my garage with the same setup or maybe 50 AMP circuit that I could use to run a machine when the stove isn't in use.  So if I do that, what kind of machine could I get that would allow me to do more TIG welding and improve my skills with that process.  I know I can also run it off my generator/welder too.  I am a hobby welder who enjoys welding and wants to see where this takes me.ThanksNick
Reply:If you have 100 amp power you have a lot of options. Do you have open breaker space in the panel? There is no excuse to mess with the range. Run from the panel with #6 copper, put it on a 60 amp breaker. ALL inverter welders will work on that, many transformer units will also.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:A 200A modern inverter TIG welder will only pull about 30A, and that's IF you run it full-tilt.  My Invertig 221 at WOT only sucks up 32A.  Since it has a 20% duty cycle, for a TIG like it, all you'd need is a #10 wire with a 30A breaker.  The Ieff rating on 230V is 12A due to the duty cycle, so it allows derating of the wire, so  10awg would be just fine for it.  Surely you can spare 30A from your 100A service for 2min out of every 10min?When you say, "welding time involves running the engine, which gets a little old sometime.", do you mean it gets old because of the expense of fuel, or because of the noise?
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:I upgraded the panel last year and there is plenty of room for additional breakers. Sometimes the engine noise from the welder/generator concerns me based on my family and neighbors.  Additionally, I learned TIG on a unit that had a HF start so that was a little better than lift start.
Reply:You can always build a sound-proof enclosure for the generator too.  I just built a "prototype" for mine to test out Roxul soundproofing material inside the walls of the enclosure, and it works amazingly well. Top, bottom, and sides are 2.5" wide, with 3" thick Roxul stuffed inside.  Front/back have downward-facing large-opening ducts; front is fresh air intake with a 10" fan to force air in, rear is where all air/exhaust exits.  Reduces sound to inconsequential levels.Last edited by Oscar; 07-08-2020 at 07:46 AM.
Reply:Check out your transformer. I share a transformer with two neighbors. Standard transformer might be 25 KW (104 amps) They'll tolerate double that for short periods. Dimming lights in the whole neighborhood prompted the power company to upgrade us to 37.5 KW.There are numerous stretches of conductors between your transformer, and welder. Each loses some voltage. Most inverter welders adjust, but transformer welders work best at or above rated voltage.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:60 amp breaker should cover it. Just make sure no one turns the oven or dryer on when you're welding. I had a Lincoln Square Wave Tig 255 transformer hooked up by an electrician on a 60 amp breaker. No problems.
Reply:Sometimes the engine noise from the welder/generator concerns me based on my family and neighbors.
Originally Posted by Louie1961
Knowing West Hartford as intimately as I do (I was a paramedic there for 10 years), I can't imagine one of your neighbors hasn't called the cops to complain already!
Reply:Yeah I actually live close by..like 20 miles west. Let me know what you get. We can set up a weld-o-rama...Miller Multimatic 255
Reply:I recommend  a primeweld 225 tig inverter, or if you want to spend  double, a sanrex   sanarg  180ap .
Reply:I run a 100' 10 ga extension cord from my basement dryer outlet to my upstairs attached garage.  The dryer isn't in use much and that gives me 220v/30a  which has never been a limitation.  I can weld 1/4 material easily all day.
Reply:I don't know anyone else in this town who welds, shoots, wrenches, etc...
Reply:I would go with a Multimatic 220 AC/DC as it has AC capability so you will be able to weld alooominum with the Tig process.The Multimatic 255 is only DC.But it's easy to spend your money
https://www.weldingsuppliesfromioc.c...process-welder
Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
That's true. About as close as you will come is someone who fly fishes and hangs out at the Orvis up in Avon. :-)
Reply:As winter draws close, I thought I would update everyone on my gear.  I decided to sell my engine driven welder and my Hobart 135.  I purchased a Miller Syncrowave 200 and then a Multimatic 200.  I was really busy with work and trying to get my exterior house work done that I didn't get a chance to use either.  A couple weeks ago, I had some free time and tried both.  I'm really impressed with both machines.  The stick and Tig welding on the Syncrowave are very similar to what I used when I took a few semesters of welding at a local community college and the HF pedal is awesome. I setup the Multimatic 200 with a spool of .035 solid wire and it also welds really well.Nick
Reply:One major point I forgot to mention.  I had a couple of engine driven welders because I thought I didn't have the power to run something like I have now.  That was based on the fact that I have underground feed to my panel and I couldn't get the power company out to upgrade my service to 200 amps.  I weld in my 2 car garage that is attached to my kitchen.  For this gear, I bought an adapter to plug into my stove outlet which is on the wall between the kitchen and garage.  I've been using that with a purpose-built extension cord to run both welders without issue.  Now that I know it works, I will have an electrician come out and wire a dedicated plug in the garage and just remember that I shouldn't weld while the stove is on.  The only downside to this setup is I live in New England and my garage isn't heated.  I've been thinking about going with a propane heater with a dedicated tank in back from the propane company.   That would be a really nice addition, particularly as it will let me work on cars and my Harley.  I would then need a fume extractor to weld.  Some things to think about.
Reply:I have a lincoln square wave 200. It was just serviced under warranty. The ENTIRE internals were replaced with a brand new unit (better design). I am looking to sell it along with all the accessories. 1200 shipped. Interested?
GMT+8, 2025-12-19 19:27 , Processed in 0.108495 second(s), 18 queries .
