Motorized Welding Turntable Build
发表于 2021-9-1 23:15:48 | 显示全部楼层 |阅读模式
Hello Everyone,Check out our latest video where Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim.Last edited by longevity-inc.com; 05-29-2015 at 12:23 PM.LONGEVITYPhone: 877-566-4462
Reply:Hello Everyone, Check out Part 2 of the welding turn table where Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim.  LONGEVITYPhone: 877-566-4462
Reply:Hello Everyone,Check out Part 3 where Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's  Innovator 255i to plasma cut the rim.LONGEVITYPhone: 877-566-4462
Reply:How is this thing coming along? Its been nearly a month since the last update..Nothing Ever Got Done By Quitting, Never Give Up.
Reply:In this video Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim. For more information on the Innovator 255i follow the link below:http://www.longevity-inc.com/innovato...Portable MIG-TIG-STICK UnitThe LONGEVITY PROMTS® 200i combines 3 welding processes in 1 machine with an impressive 200 amp MIG welder, 200 amp TIG welder, and 170 amp STICK welder.Easy Push-Button SetupThe PROMTS® 200i is very user friendly! All theadjustments are properly spaced and coded which allowsfor easy on-the-fly adjustments. The grouped and codedsystem allows the user to see the settings quickly andmake necessary adjustments easily, allowing the welderto more efficient in the workspace and a fine shaped arc!Powerful, Reliable, Efficient IGBT TechnologyLongevity offers cutting-edge technology in thePROMTS® 200i by including IGBT semiconductors insidethis unit. IGBT technology makes this unit more reliablethan other comparable units using old-fashionedtechnology. By using IGBT components, LONGEVITY isable to offer a potent welder that is lighter and morespace-efficient than its outdated counterparts.Digital Amp and Volt MeterBy using digital meters, LONGEVITY gives the operatorinstantaneous outputs which are easily read while welding.This allows the user to dial-in their favorite settingsaccurately, again, and again!Larger Wire Spool CapacityLONGEVITY understands the importance of time andmoney. With this PROMPS® 200i, you are able to use 11lb spools for longer welding times without having tochange the spool. This also saves you money as you areable to buy larger spools at greater discounts. Do notneed to use that much wire? No worries. You are able touse small 1lb rolls of wire without additional equipment!Burn Back ControlLONGEVITY uses Burn Back Control to prevent excessamounts of wire from sticking out by providing extra arctime without feeding. This allows the user to makeexcellent re-starts as smooth and painless as possible.Stick With Adjustable Arc ForceWith Arc Force, you are able to adjust the inductance ofthe arc for either a crisp arc or soft arc with a fluid puddle.This will allow for greater control of your weldingparameters.LONGEVITYPhone: 877-566-4462
Reply:Hay Rob,I don't know if you read these comments after you post the video. But if you do, the reverse switch for the motor is not needed because you used the bike sprocket and it only free wheels in reverse.And by the way this was part 5 not 4Last edited by mechanic416; 05-28-2015 at 09:03 PM.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2025-12-19 19:25 , Processed in 0.099795 second(s), 18 queries .
