Welding Turn Table Part 7
发表于 2021-9-1 23:15:47 | 显示全部楼层 |阅读模式
In this video Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim. For more information on the Innovator 255i follow the link below:http://www.longevity-inc.com/innovato...Portable MIG-TIG-STICK UnitThe LONGEVITY PROMTS® 200i combines 3 welding processes in 1 machine with an impressive 200 amp MIG welder, 200 amp TIG welder, and 170 amp STICK welder.Easy Push-Button SetupThe PROMTS® 200i is very user friendly! All theadjustments are properly spaced and coded which allowsfor easy on-the-fly adjustments. The grouped and codedsystem allows the user to see the settings quickly andmake necessary adjustments easily, allowing the welderto more efficient in the workspace and a fine shaped arc!Powerful, Reliable, Efficient IGBT TechnologyLongevity offers cutting-edge technology in thePROMTS® 200i by including IGBT semiconductors insidethis unit. IGBT technology makes this unit more reliablethan other comparable units using old-fashionedtechnology. By using IGBT components, LONGEVITY isable to offer a potent welder that is lighter and morespace-efficient than its outdated counterparts.Digital Amp and Volt MeterBy using digital meters, LONGEVITY gives the operatorinstantaneous outputs which are easily read while welding.This allows the user to dial-in their favorite settingsaccurately, again, and again!Larger Wire Spool CapacityLONGEVITY understands the importance of time andmoney. With this PROMPS® 200i, you are able to use 11lb spools for longer welding times without having tochange the spool. This also saves you money as you areable to buy larger spools at greater discounts. Do notneed to use that much wire? No worries. You are able touse small 1lb rolls of wire without additional equipment!Burn Back ControlLONGEVITY uses Burn Back Control to prevent excessamounts of wire from sticking out by providing extra arctime without feeding. This allows the user to makeexcellent re-starts as smooth and painless as possible.Stick With Adjustable Arc ForceWith Arc Force, you are able to adjust the inductance ofthe arc for either a crisp arc or soft arc with a fluid puddle.This will allow for greater control of your weldingparameters.LONGEVITYPhone: 877-566-4462
Reply:progress? keep us in the loop!Nothing Ever Got Done By Quitting, Never Give Up.
Reply:I guess Rob went on a long vacation or ran out of parts
www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Well I guess Rob gave up on building a turn table
Reply:" frameborder="0" allowfullscreen>Last edited by longevity-inc.com; 07-30-2015 at 02:30 PM.LONGEVITYPhone: 877-566-4462
GMT+8, 2025-12-19 19:23 , Processed in 0.118419 second(s), 18 queries .
