time to change...PLEASE!!!
发表于 2021-9-1 23:15:46 | 显示全部楼层 |阅读模式
Hello Longevity..I am on my third Longevity machine. I just got  a new 250EX.   and I have to go through the same set up process. again.I work from a wheel chair in my shop and these issues have an impact.Please send this back to your mfg people.1.    Move the power switch from the back of the machine to the front/side...!!! It is a real pain to have to get up and reach around and turn off the box.2.    put a standard NPT quick connect for gas interface. or just put an NPT fitting there and we can put on the type that suits the shop.I have to do this each time and it does get old.  Keep up the machines.Mike Hackett
Reply:I think the reason for the switch on the back of the machines is because it also is a breaker for the Machine and makes more sense from a manufacturers point of veiw to put them their, I just have gotten use to my machines and adapted fittings to quick connect 1/4 inch for torches. Sent from my SM-N915W8 using Tapatalk
GMT+8, 2025-12-19 19:53 , Processed in 0.069366 second(s), 18 queries .
