Need Help Longevity Migweld 140 problem
发表于 2021-9-1 23:15:44 | 显示全部楼层 |阅读模式
I am new to the forum and am hoping someone may be able to help me out.  I have a Longevity Migweld 140 and it worked great for the first year or so that I used it and now all of the sudden it will kick my circuit breaker every time I hit the trigger on the gun.  Its not my breaker as it is dedicated 20amp and I have also tried several others.  I have tried taking all the tension off the wire and tried adjusting wire speed up and down but regardless the second you hit the trigger the machine shuts off (kicks my breaker).  I tried calling Longevity but apparently they only have one technician and he never called me after about three weeks of calling them and being told he would be calling me the next day.  Never got a call back.  The welder is out of warranty and Im just looking to see if anyone has any experience with this type of issue.  Im a mechanical engineer so I understand electronics and am pretty good at fixing things, just a little out of my realm with this machine.  I am very disappointed with Longevity since I have hardly even used the machine.  I just finished my second 2lb spool of wire on it before it crashed out on me.  Any thoughts or ideas on what I can do is very much appreciated.  I live in Phoenix and may even be willing to take it in if I knew where to go, really hoping its something small that I can fix myself.  Thanks
Reply:There are two members here who had Longevity Stickweld 250s. One of the welders I got to run a couple times. Both welders started losing power. Longevity replaced both welders. But the replacement welders started doing the same thing! I suggest you round file it, and go buy another brand.Don’t pay any attention to meI’m just a hobbyist!
CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST
3 SA-200sVantage 400
Reply:Take the welder and launch it in the nearest recycling dumpster. It's not worth fixing or the stress your going through. Being a engineer why purchase this welder in the first place? Just do a search for this manufacturer and you will see enough feedback on this company.
Reply:I did do some research before I bought it and I guess I was fooled by some fake reviews.  There were also a lot of youtube reviewers that spoke highly of it however hindsight is 20/20 I guess I should have tried to get onto some welding forums like this to get some real feedback.  It welded fine before this happen and was working great for me, I was just hoping I could salvage it with an easy repair.  I guess my goal now will be to go leave tons of negative reviews in as many places as possible so others dont end up in my situation.
Reply:Thats a tranformer machine. Shouldn't be that hard to troubleshootSent from my LG-H811 using TapatalkMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
GMT+8, 2025-12-19 19:53 , Processed in 0.069481 second(s), 18 queries .
