2015 Everlast PowerTig325 EXT DUAL VOLTAGE 1PH 220v and 3Ph 220/460v
发表于 2021-9-1 23:15:43 | 显示全部楼层 |阅读模式
We now have two versions of the 325 EXT. The new units now put out FULL amperage of 320 amps on 1 phase 220V. They will also operate as always on 220V 3 phase. We also have a 1 phase 220V/ 3 phase 460V version. Will only need a 60 amp breaker for max output (54 amps or so max inrush) on 1 phase 220V. 20-250 amps on Stick. Also minimum TIG amps @ 5 A (AC and DC  ).Some of you guys have been waiting for it. All other ways it should be very close to the 255ext. Duty cycle should be around 35% at max output Units are in stock...ready to ship. Those of you waiting on the 255ext may want to step up and get a good bit more power.
Oleg [email protected]/650 588 8588 x201www.linkedin.com/pub/oleg-gladshteyn/48/b08/875
Reply:I can't wait to buy one!  Could you give me the dimensions on this welder....I'm building a cart and want to make sure it will fit before I weld it up.  Thank you!!
Reply:Just ordered mine with the water cooler. Should be in next week. Pretty darn excited.Drag Racing is for Fast Cars. Time Attack is for Fast Drivers!Miller Dynasty 200DX SOLDWeld Tec WatercoolerSOLDMiller Millermatic 180 w/ Spoolmate 100 Everlast 325 EXT w/300 Water Coolerwww.felixperformance.com
Reply:Nice,That'll be a powerful and advanced TIG set-up.
Reply:I am thinking about buying a tig welder dynasty 210 or everlast 255 ext which is better
Reply:I think your question would depend on your budget and the application for the machine. I have had good luck with the 255EXT so far, but I have back up machines in my shop if something were to go wrong with it. LarryMiller XMT 304 CC/CVSyncrowave 180 SDLincoln PowerMig 255XTTermalDynamics 52Lincoln 305GComlpete machine shop to back it up
GMT+8, 2025-12-19 19:48 , Processed in 0.091140 second(s), 18 queries .
