Want to use Miller HF box on Everlast 210EXT
发表于 2021-9-1 23:15:43 | 显示全部楼层 |阅读模式
I have a 5yr old (almost) Everlast 210EXT.  I've spent time with Everlast Support on how to make it stick weld better. It sticks the rods too much and won't hold a medium or long arc even when lighting up or welding.  (No need to discuss changing rods, bad rods, hot start, arc force - I've been through all that.)SO.... I'm wonder if I can use a Miller HF251 high frequency box to impress HF on a stick weld operation?  Maybe this would help maintan an arc and easier starting.Any ideas, anyone tried this?J.p.s.  I've been satisfied with the TIG welding on this machine, just not the stick welding.
Reply:The unit won't weld E6010.  That's for certain.  But the unit is not designed for a long arc for any rod. It keeps you honest. But no, you will blow the circuits on the unit adding HF to it.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:40 , Processed in 0.092978 second(s), 18 queries .
