206pi Question
发表于 2021-9-1 23:15:42 | 显示全部楼层 |阅读模式
Im trying out the tig for the 1st time. Do i have to put the torch on the work piece side or does the unit switch to torch ground its self?Current welderHobart Handler 187Dead weldersHF 151 dual migCraftsman Welder 20511Craftsman Welder 80amp FluxI killed them LOL!!!!
Reply:The torch goes on the torch side for TIG.  For stick, it is reversed. For plasma, it goes to the torch side. Did you download the manual?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:42 , Processed in 0.095592 second(s), 18 queries .
