I have a PPro 256Si. I would like to run a manifold ( Tee Block ) to control both the air/gas into. I would prefer one way valves as well so I can just turn the argon on and the air off or visa versa to run thru the machine. I can find plenty of 1/4 in suggestions but the 256Si uses a 5/8 CGA fitting. Anyone have any suggestions? I would like to mount this on the top and connect a single line down to the gas receiver at the bottom of the machine.
Reply:There are plenty out there. The 5/8 CGA is common and standard in the industry. Western has one. https://www.weldingstore.com/product...hoCrrcQAvD_BwEEsab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
