Power i-MIG 315. Basic MIG, smart buy
发表于 2021-9-1 23:15:41 | 显示全部楼层 |阅读模式
The new Power i-MIG 315 has arrived.For those looking for "just a basic  larger MIG" this is the one for you.  With output at 315 Amps @ 35% duty cycle and 250 amps @ 60% duty cycle, this is a MIG ready to weld.  No synergic or power set functions. However, it is well equipped with some of the finer points of a larger MIG machine that are often offered as options.1. Self contained, with its own under carriage and cylinder rack.2. Auto pre/post flow.3. 4 roll gear driven cast aluminum and steel wire feeder capable of up to 700 ipm4. Burn Back  Control5. Spot and Stitch timers.6. Arc Force/Inductance Control7. Stick Function8. IGBT inverter based.9. 5 Year warranty Parts and Labor.10.  240V 1 phase input. (Inquire about 3 phase needs).
Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Price?  I don't see it on your site.edit, found it :  $2099 in the US, $1700 in CanadaLast edited by Chad86tsi; 05-20-2020 at 12:44 PM.Everlast 350 EXT       -        Thermal Dynamics Cutmaster 52         -         Rogue Fabrication M600 xHD tube benderMilwaukee 4208 Mag Drill          -         Shopmaster Eldorado Combo mill/lathe machine with DRO.
Reply:Call us, we'll have a special deal on it for those that call direct.877 755 9353 ext 204 for me.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:45 , Processed in 0.091038 second(s), 18 queries .
