Lightning MTS 225
发表于 2021-9-1 23:15:40 | 显示全部楼层 |阅读模式
The Lightning MTS 275 has been a success and producing them as fast as we can sell them.  We've also introduce its smaller sibling the Lighting MTS 225.  Same type of unit, with AC/DC TIG (Pulse on both DC and AC), wave form control. etc.   There are a few minor differences as in keeping with our design philosophy, the more amperage you need, the more features you are likely to require. It has less wave forms, but the ones you need.  No spot or stitch timers, but the unit is still well appointed. This unit is the replacement for the PowerMTS 221STi.   It is in stock and is selling well as well.  The unit is smaller physically and is only 200 amp output.  It holds a 10 lb roll of wire.   But it also has the powerset function like the Lightning MTS 275. It is dual voltage and has two input for both MIG and TIG gas, so you can keep both gases connected at the same time.https://www.everlastgenerators.com/p...25-tig-package
Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:46 , Processed in 0.093652 second(s), 18 queries .
