Double and Single Synergic Pulse MIG Power i-MIG 353DPi
发表于 2021-9-1 23:15:40 | 显示全部楼层 |阅读模式
If you haven't seen the new addition to the Pulse MIG line up from Everlast, Everlast not only has one synergic single and double Pulse MIG it now has two that are single and double pulse MIGs.  The New Power i-MIG 353DPi is available with a separate wire feeder which can be detached and carried to where you are working.  With 350 amps and a 60% duty cycle this unit is built for serious industrial and commercial use. It comes with a watercooler and cart, ready for use. It will support push-pull, or spool gun use as well as a teflon liner with the standard Gun to feed aluminum.  It has settings for Steel, Stainless, Aluminum, and Silicone Bronze Brazing.  It comes with the standard 5 year warranty.  It is single phase 240 and can operate on 3 phase 480V.
Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:47 , Processed in 0.066589 second(s), 18 queries .
