Hi, I'm looking for a 1/16" V-groove drive roll to fit a Linde/L-tec/Esab SWM-23 or a MIG-35 wire feeder. The roll is about 2" in dia. and 1" wide with a 5/8" bore with a keyway. The center is plastic. I believe the part number is 2075299. If anyone has one they would sell or could recommend a source, I'd appreciate it. Thanks, EdLincoln DC 250 MK, Hobart MB 304, Miller Dialarc 250 HF, Syncrowave 300, 330 A/BP, Goldstar 300SS, SR-300, Maxstar 91, 140, 152, Westinghouse FlexArc 300 AC, 200 amp w/spool gun, Linde SVI 400, 450 pulse, SWM-23 & Mig 35 feeders, Cobramatic feeder
Reply:I believe the L-Tec / ESAB Digiming feeder used that feed roll as well.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC ( Sanrex )ESAB 301i AC/DC ( Lorch )Thermal Arc 161STL ( WTL )Thermal Arc 190S ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:Thanks for the input. I just did a little searching and found a manual for the Digimig. You're right, it does take the same drive rolls. This should help.Lincoln DC 250 MK, Hobart MB 304, Miller Dialarc 250 HF, Syncrowave 300, 330 A/BP, Goldstar 300SS, SR-300, Maxstar 91, 140, 152, Westinghouse FlexArc 300 AC, 200 amp w/spool gun, Linde SVI 400, 450 pulse, SWM-23 & Mig 35 feeders, Cobramatic feeder |
