查看: 13|回复: 0
The Importance of Shielding Gas
发表于 2021-9-1 23:15:36 | 显示全部楼层 |阅读模式
So a few days ago I posted a question about whether to upgrade my new Spray Master 250 MIG torch to Velocity2 consumables.I had set up my new Rebel EMP 235ic and made some test welds, and, to say the least, was NOT happy with my results. I had a feeling something was really not right, comparing how my welding was going compared to so much MIG work I've watched on Youtube.And I really thought I'd been careful to set everything up correctly.HOWEVER, it turns out I didn't have the torch connector plugged fully into the wire feeder. I had definitely loosened the locking thumbscrew nearly completely, but hadn't pushed hard enough to fully seat the o-rings in the bore.When I got back to my shop today, the first thing I knew I needed to check was that the gas was getting to the torch, because I realized my welds looked like I'd run out of gas or something. I put the torch near my ear and pulled the trigger, and could not hear any gas flow from the tip.So I loosened the thumbscrew, pulled the torch connector completely out, examined it, and carefully plugged it back in while observing the gap at the feeder. See this photo, which shows the tight make-up of the black connector against the feeder housing; this is as it should be.
BIG DIFFERENCE HAVING GAS FLOW TO THE TORCH!!Below are my first three beads at top, without hardly any gas flow. The bottom three beads are today, WITH gas flow:
Same beads after a bit of wire brushing (and better camera focus!):
That was a piece of 1/8-inch hot rolled sheet.Then I tried spray transfer (since my gas is C15) on a piece of 1/4-inch hot rolled plate. The bead to the upper left was definitely spraying, based on the sound:
Same image after light wire brushing:
The last bead, at upper left, was at 450 IPM wire feed and 28.0V. This is all with .035" wire (Aristorod 12.50 copper free). Gas flow about 30 CFH.For some reason it starts out spraying nicely, no popping or bacon sound, pure hissing; then after maybe 2 or 3 seconds it degenerates to some popping and not so clean of a hissing sound.I'm wondering whether that could mean I should turn up the gas flow?Also after the welding stops the display is showing only about 165 amps; I would have thought with 450 IPM and 1/4-inch plate the current would be higher for 28 volts.BTW, I tried to maintain a wire stick-out of 5/8", and I did notice this nozzle/contact tip combination has the contact tip recessed about 1/8".The welder is running on a 240 VAC 50 amp circuit, so there shouldn't be any lack of input power.Do you think I need to turn the WFS up even higher to force the amperage up?There is no doubt this is putting down a lot of metal in a hurry, and also putting a lot of heat into the plate!!It's also obvious I need to start working on running a straight, parallel bead, and to keep the torch speed constant. Easier said than done!But you can see from the first three beads at the top of the photos, why I was REALLY disappointed with my first welding attempt!!
I am planning to get some in-person training from a local welder who has agreed to help me. This is just me setting up the system and wanting to get familiar enough with the equipment and setup to be able to really absorb what he's going to teach me.
Reply:It's also obvious I need to start working on running a straight, parallel bead, and to keep the torch speed constant. Easier said than done!
Reply:remove "spray transfer" from your vocabulary for now. try welding something together VS bird turds. you will soon learn you are too cold. crank it up. try a T joint.... it's pretty easy.... kinda like walking the cup/nozzle....   and it traps the gas in there....      then beat it with a hammer and see where it fails.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Regardless of what amperage the machine is showing, it should be in spray transfer at that voltage and wirespeed, assuming C15 gas. It's crackling because the wirespeed is good and high.settings sound good to me. You need to run some proper joints to verify. It will run differently than it does just running a flat bead.
Reply:A poor ground connection will often cause the popping.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:These are mass produced engines that arent really anything special... any decent gas station where the gas doesnt sit for months should be fine.
Reply:450 IPM with .035 wire = 220 amps at least180 amp spray transition currentso I'd say it's well in spray transfer amperage
that's why I said regardless of what it's showing on the display.
Reply:But he said the display is showing 165A, so something is off.  It could be as simple as too long of a CTWD.  Maybe the wire is 1 or 2 thousandths undersized.  Maybe the work clamp is corroded to hell and grabbing onto rusty millscale.  Just saying.
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Yes, you're right there.
Reply:Thanks guys for all the discussion and tips. I did forget about spray transfer based on John T's advice above. The first project I undertook after building my CertiFlat table was a dust collection system. This involved 3 frames welded from angle stock, plus a blower housing and a filter housing. I returned the ESAB Rebel and bought an HTP Pro Pulse 220 MTS. I really like this machine and it has worked well for me. I've learned some DC TIG as well. Jody's videos have indeed been very helpful. When I have good access, good positioning, and good visibility, I feel my welds are coming out very decent. I still struggle a lot when welding joints with limited access.
Reply:Thank you for this thread!
GMT+8, 2025-12-19 19:43 , Processed in 0.164600 second(s), 18 queries .
