Powercut 1300 Help.
发表于 2021-9-1 23:15:35 | 显示全部楼层 |阅读模式
I was cutting with it tonight it was working like a champ then it stopped. Showed E21 PIP No Continuity. Replaced nozzle and electrode. Checked air at 80 psi. Still does not work. I have air coming out of torch on power on. The air stops and then the E21 code comes back. Anyone have any ideas?Thanks,Todd
Reply:E21, if new tip and electrode in torch don't help.Do a continuity check on torch lead. make sure no leads are broken.If torch lead is good. then you might be looking at a new pilot arc IGBT.Hopefully there is not a problem with the control pcb that drives the IGBT.
GMT+8, 2025-12-19 19:47 , Processed in 0.090807 second(s), 18 queries .
