PowCon 300SM remote pinouts?
发表于 2021-9-1 23:15:34 | 显示全部楼层 |阅读模式
I have a 300sm hooked up to a hobart feeder running ulltracore wire. Welds really nice, but the terminals are allways hot. Id like to hook up a contactor switch to the remote plug to controle the termainals. Need to know what pins do what. Also my plug is not numbered so I need to know where pin 1 and 14 are.Thanks
Reply:Manual can be downloaded here. http://www.arconweld.com/Powcon_Oper...1C%20300SM.pdfTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Thanks, allready think I have it figured out.. Will post my results and how I did it.Edit.What I found in the manual.pin 1 = line 115vpin 2 = netural 115vpin 3 = gnd pins11 and 10 = enablepin 12 = +16pin 13 = wiperpin 14 = OVpin 8 = contactor inpin 9 = contactor outalso found some good info here.http://www.practicalmachinist.com/vb...nector-132015/Edit.If pin 12 is 16volts DC I might be able to use a simple 12 - 24 volt DC relay to power the coil. I think I need to connect pin 10 and 14 to put it into remote mode (out put terminals open/off) then connect pin 8 and 9 together to enable (out put terminal closed/on), Im thinking a simple auto motive relay will do this.. Not sure how I will close the relay, Might just tap it to the gun triger. I think the feeder is powered by the output voltage of the welder. ( dosnt use 42v or 115v ) and dosnt have a contactor out put conection installed. (will see wihen I pull the cover)Last edited by Sgnob; 11-09-2014 at 03:17 PM.
Reply:Tried to send you the 300SM manual but it said it exceeded the limit of 150. I have all the manuals that Arcon has downloaded on my computer. I have several short pigtails if you need one. I think I've got some 14 and 17 pins. the 400 series, depending on manufacture date takes the 17 pin. My 300SM takes the 14 pin. Yes, I know, more useless info........Just happy we have the POWCON site.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal Mill
Bryan
Reply:What do you want for a 14pin pigtale?
Reply:Here is where I have ordered several plugs for multiple Powcon machines.   http://www.mouser.com/Mobile/Connect...ors/_/N-9uhfv/ There are at least 4 different plugs in use on the common models r that I have come across.   Just match the part number to the one printed into the plug on the machine.   And yes they are expensive plugsTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Pin 8 and 9. Complete a circuit to close the contactor.  Do not put any external current to any of the Powcon pins unless you want to fry your machine.    Whatever the voltage running through the Hobart gun trigger needs to be used to connect the normally open side of the trigger to a relay that will close the contact between pin 8 and 9.  Got a 12vdc relay pin 8 ands 9 connect to terminal 87 and 30.    Gun trigger goes to 85.  ground terminal 86. Assuming your trigger is 12vdc positive.   If it's 24vac trigger for example  get the appropriate relay.    If this does not make sense,  find someone that it does.  Have them do it.      I did several Miller feeders to Powcon machines this way.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Powcons work backwards. Close 8to9 and the welder output turns off.everybody else you close the contacts to turn welder output on.Check the contactor control relay in your feeder and see if it can be switched from normally open to normally closed.
GMT+8, 2025-12-19 19:45 , Processed in 0.096461 second(s), 18 queries .
