Anyone with a 400 SMT willing to take a picture for me?
发表于 2021-9-1 23:15:30 | 显示全部楼层 |阅读模式
Trying to fix up a 400 SMT I bought with some other equipment.  Talking with Arcon they suggested replacing main caps and one of the SCR pucks.  Did that, still no output even though the main board is firing a signal at the SCR's.  Someone had been in this machine before I was so I'm wondering if they didn't misplace a wire, I need a picture of where the wires connect to the top of the bolts holding the "main SCR assembly" to the white plastic frame, and another picture of where the SCR wires connect to the bottom of the main board.Thanks!
Reply:Hang tight.
From left to right 6,7 4,5 10,11 8'9
Reply:Any chance you can read the value off of c8?  It seems to have lost the magic smoke.  Possibly from having 110 run through the contactor circuit?
Originally Posted by benc
Is this more helpful?
Reply:Sorry I meant studs on top of the white plastic - where the main SCR assembly (the big heatsink with two SCR pucks wedged in between) bolts to the underside of the white frame.  There's a red and yellow wire going to them
The fan side
The control panel side
Reply:Thanks much.
GMT+8, 2025-12-19 19:48 , Processed in 0.067827 second(s), 18 queries .
