Powcon 300sm w/o feeder--good/bad
发表于 2021-9-1 23:15:30 | 显示全部楼层 |阅读模式
I have a Lincoln tombstone AC/DC (the little one, not idealarc).I know someone with a Powcon 300sm, but no feeder, under $300.  Is that going to do anything for me?  I was thinking more for using it as a scratch tig box, but now and then a wire feeder comes up and might be compatible.  I've held off getting a mig only because of limited space, and inverters are pricey.  So maybe this plus a feeder gets me a 2-for-1.I know these were built well, but they are old.  I figure won't outlast my tombstone. Is there any advantage over what I have now?  Little lighter weight.  Higher output & duty cycle.Also, the "power level" knob is strange vs. amps.  Seems that would be hard to set.What I really want is an inexpensive HF starter so I can use low amps to stick weld thin stock.  I know this doesn't get me that.
Reply:I have used one in the past.  One of the nicest arcs for stick welding I ever used.  I was really disappointed when it expired.For you, definitely a step up from that Lincoln, not a lot of money and you can find a used feeder for it.  I'd just get a suitcase feeder for it, Lincoln or Miller."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:Great welders, I would not hesitate to buy for that price. Almost any feeder will work and eBay always has some old Powerdrive 1 or 2's for sale that plug right in if you want to make it easy. You won't want to use the tombstone after you weld with the Powcon.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:It's cheap enough - I'd buy it
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Wow, unanimous.  Thanks guys.  Didn't know I would notice any difference in the stick welding, but then I've only used the tombstone so no comparison to anything.
Reply:Looks like the guy blew me off.  Had a bad vibe about that one, anyway.  I'll keep looking.
Reply:Just about any 24 volt wire feeder can be used. You just have to add a relay to reverse the welder control from normally open to normally closed.The 200sm takes a closed switch to turn the welder output off. Change the plug to match the powcon.
GMT+8, 2025-12-19 19:47 , Processed in 0.091772 second(s), 18 queries .
