Thermal arc 150gts
发表于 2021-9-1 23:15:27 | 显示全部楼层 |阅读模式
I just got this machine and I can't read the face on it some one went after it with carb cleaner.I tried calling esab/thermal arc and no manual avaliable.    I can only get power out of one setting on the selector switch
Reply:https://manualzz.com/doc/6320756/the...anual_-0-2493-Maybe in the stick mode for power.. Might need to jumper some pins to get the lift-arc to work.. Most of those models took a button control for the tig contactor.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:you will need to jumper pin 2 to pin 3. remote controls are still available,ESAB is using the same pin configuration on their current equipment.For panel TIG operation you need the jumper plug. to turn on the welder output.
GMT+8, 2025-12-19 19:45 , Processed in 0.092443 second(s), 18 queries .
