Thermal arc porta feed 17a feeder
发表于 2021-9-1 23:15:26 | 显示全部楼层 |阅读模式
I'm looking at purchasing an older suitcase wire feeder. The thermal arc porta feed 17a. In my research I find the manual saying it will run on any cv or cc/cv power supply. I can't find anything that tells me it's a voltage sensing feeder that will run specifically on a cc power supply.  Anyone have any experience with this unit running on a cc only power supply?The manual for the thermal arc hefty 2 suitcase feeder does specifically state it will run on a cc power supply, powered across the arc and voltage sensing. But I just can't find this info for the porta feed 17a suitcase feeder. The owner says it will run on a cc power source but I want to confirm this myself before making the purchase. Thanks.Last edited by snoeproe; 08-09-2015 at 09:04 AM.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Looks to be it runs off 115 VAC. This one has Hobart branding, but they're likely the same. Can't say if it's an energized contactor or not, but it's not a big deal to hook it up either way. Being its a constant speed feeder (at least it appears to be from here) it will only run off CV power sources. Can't say for sure tho and the manual didn't really get specific about it.Here's a discussion about it too. I think Scott (Brand X) owned one, or possibly did at one time, him and Don (DDA52) are discussing it here.http://www.hobartwelders.com/weldtal...p/t-18009.htmlHere's a Victor manual on it. Looks to be the same thing.http://victortechnologies.com/IM_Upl...430429_402.pdf
Last edited by 7A749; 08-09-2015 at 09:51 AM.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Yes. This is what I figured. I have viewed the Victor manual already. It isn't really clear on the questions I have in regards to power supply. I'll have to pass on it seeing as I don't have a cv power supply to run it.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I had two.. hooked one up to my Shopmate for a bit.. The manual says CV and CV-CC power source in so many words. What it is really is telling you is it's for a CV power source only..
Great little two roll feeders anyway.. Had one also hooked up to a Esab 350 MPI, and Thermal-arc MST-400 all are CV-CC power supplies.. (ran on CV) http://victortechnologies.com/IM_Upl...430429_402.pdfI was able to buy two at different times. Both new from Ebay, and about $300 to $400.. What a nice feeder for that price..
Last edited by Brand X; 08-09-2015 at 10:13 AM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Steve, you can wire for 120 volt contacts too.(Yes wired for closing contactor from the factory) Pulled power from the wall on the Shopmate. Esab was a bit different, and I needed help from Dea at JustArc to wire up.. ( had help from here from our tech here, but Dea put it into English for us laymen.. Both were saying the same thing..
Told me some Miller's can wire up the same way.. It was about turning on the 115 volt contactor in the machine.. Interesting to say the least. Still have the email...Scott,Sorry about all of the delay, I am old school when I try to read and draw schematics.  For the past few days I have been on the run and using my phone.Your diagram may not work. I would recommend the following;Change your feeder back to "contact closure" and wire as follows moving the Thermal Arc wires to the ESAB pins;Esab                                      Thermal ArcA         115 vac hot                E and AB          115 vac neutral          FC          Contactor                   BD          Ground                     GThe reason for this is that when Miller and Esab use this three wire system it is easy to get the 115vac neutral in the wrong place and it will drive you nuts trying to figure out why it should work being AC but there is no "polarity" or "difference of potential".  Or worse you put 115 on top of a 115 trying to get out!Again sorry for the delay, keeping you up and running in a timely manner is important to both of us. I am happy to help and look forward to hearing from you again.  I would not think of charging you for this if it helps and you come back later...or spread the word, thanks Take careDea
Originally Posted by 7A749
Sounds like it Scott. I figured by the discussion you had with Don then that you either had one or had familiarity with them.Snoeproe.....  what is the price on it? It may be worth picking up if it's cheap. You can modify the connector cord to support a variety of different CV machines. It wouldn't be hard and if were only talking a couple few hundred bux, that's a great price for a feeder like that.Be a great excuse to buy a CV power source then
IMHO of course
Reply:Pass for sure.I'm sure it's worth that to someone, but not to me...Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Hello friends I bought 3 cheap thermal arc 17A, I am repairing them of the 3 I have 1 repaired. I can use this feeder with a miller XMT304 CC / CV welder. The connector has 5 cables. the 3 current and ground and 2 more. How should I connect it to that machine? Greetings from Venezuela Thanks for the help
Reply:diagrams do not appear to be available on line any more for the 17A.I might have some in hard copy, will have to look when I get time.If you have figured out the function of each wire in the control cable I can help you connect to the XMT unless it is a new one.I am pretty sure it needs 115 volts to operate. On other older feeders. of the five wires two should be power, one is ground and the other two are contactor control.If Your XMT has two circuit breakers on the back panel then you have 115 volts in the 14 pin feeder plug if only 1 then only 24 volts is available.In the XMT owners manual there is a chart showing how each pin is used. There is a couple of ways a feeder can be connected to the XMT.one way uses an isolated contactor control and the other uses a voltage return.You should be able to download owners manuals from millerswelds.com.look at the s-52 feeder for a 117 volt feeder. s-22 for a 24 volt feeder.Both use a hot return. you can get 115 volts from pins I and K.you can use A to B for isolated (dry) contactor control.
Reply:Found a copy of the owner's manual.send me your e-mail by private message and I will send it to you.these units do operate on 115 volts. pins e and F . pin G is ground.A and B is contactor control no power, just relay contact closure.
Reply:ccawgc,I took some pictures of my ThermalArc Fabricator and 17A feeder that I PM'ed you about (to see if you might have manuals).  The welder if a Fabricator with analog dials and I haven't seen any other pictures of one like mine.  I've messed around with it, and I think that it will weld, but I haven't actually tried it.  Problems that I've had (and think that I've fixed) were a missing 7-1/4A fuse on the welder front panel (replaced w/10A button breaker), stuck contactor in the machine (freed up) and a bad selector switch on the feeder (3-position switch - bypassed).
Reply:This is a Hobart in TA Clothing if that helps.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
Reply:Humberto, When I got it and took the covers off, it was very dirty inside so I did use compressed air to blow it out.  I had to figure out how it worked because it wasn't giving me any voltage on the output lugs no matter what I did.  I think that I got the contactor to work by poking at it with a wooden stick.I haven't opened up a lot of welders, but this one seems to have an unusual transformer that looks like a "J" on its side.Also the circuit board that controls the cooling fan in the welder was jumpered by the previous owner and runs constantly.  I left it that way.  It probably more noisy, but I guess safer to run coolerMember ccawgc sent me copies of my manuals (thank you again!), so I may poke around with it a bit more.  I may be modifying the front panel to work around the faulty WireFeed/Purge selector switch.
Reply:Might be the RC-300
Rondo, do you know what the equivalent Hobart model is to my welder or are you just talking about general features found on Hobarts of that vintage.
Originally Posted by ccawgc
Might be the RC-300
Call Mike Huelsman in Ohio. He's a Hobart TA Guru. 419 953-5964.  He was around when Hobart disbanded and was re-badged TA. ITW got the smaller machines and Thermadyne got the large ones. He's a major archive and service center. Good Luck
Reply:IF you need a owner's manual for a Hobart welder. ITW Hobart has all the old Hobart manuals and if you call them they will email what you need for free or mail you a hard copy for $15 last time I looked. Just go to the Hobart welder web site and get the phone number or use the contact page.
Reply:I have to keep telling the ownership to leave my archives of old welders alone.With them I can fix a lot of the old machines be getting creative on parts.With out them we have no chance to fix them.
GMT+8, 2025-12-19 19:27 , Processed in 0.097193 second(s), 18 queries .
