So i am going to pull the trigger on the powermax 45 xp but Im not certain which bundle to go with.I need the CPC port, and will be using it with a Langmuir crossfire that i intend to try and upgrade to have a Z axis and machine torch down the line.At the moment it only has a mount for a hand torch. Ideally I would like to have a torch for hand cutting and another torch for the plasma table. This is making me lean towards this bundle below. But why does it seem too good to be true that it comes with two torches? The 15 degree torch is actually ideal i think because it aims the torch hose up and out of the way. Whats going on that it cost $450 to buy the hand torch separately but this one comes with two forBarely any more money? https://www.bakersgas.com/HYP088124.html#25264www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Edit Post. I misread your post. Ya not sure does that mean either or, or both.Last edited by TJS; 02-11-2019 at 11:22 AM.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:Fired up my pm85 for the first time in years when i fired the machine torch on my table. I have an htp 380 for hand cutting since 2003 and still kicking. Yes the regular torch for the hypers are not cheap.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:85?? That’s a big machine lol. Cutting bank vaults in your shop?www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:I'd like to have a separate machine torch for my table as well. Or even just a second hand torch.12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:There is a package price for a 45xp with a machine torch and a 75 degree hand torch. That is the one I would recommend. If you plan to use a hand torch on your Langmuir machine keep in mind that the CPC port will not start / fire a hand torch (the 75 degree and the 15 degree hand torches are fired via hand trigger switch), so to use one of those torches on a machine means you will need to read the wiring diagram in the service manual and hack into the internal machine wiring. The CPC port (pins 3 and 4) will fire a machine torch (no trigger switch, designed for machine cutting).Jim Colt
Reply:Wow. That is some great info right there Jim.www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
Reply:I ordered the 75/15 torch kit and I guess I will have to figure it out to make it work for now.The machine torch/hand torch combo is no bargain really...Its the same price roughly as the hand torch plus the machine torch separately. Maybe $100 cheaper. Kind of strange the 15 degree torch is only an extra $50.Jim, i assume doing what you stated to use the hand torch voids the warranty?Last edited by BrooklynBravest; 02-14-2019 at 02:15 PM.www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:I caved and decided to order the machine torch with hand torch kit...What does the remote pendant do? I see it is included and its not a cheap item.www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:The remote pendent is simply an on/off switch for using the Powermax plasma with a machine torch on non-cnc machines such as a track burner or a portable pipe cutting machine. This combination with the hand and machine torches is often used with those types of machines. For your cnc machine....which controls the start and stop of your Powermax there is no need for a remote pendent. Jim Colt
Reply:The remote is momentary on or continuous cutting with it's dual mode switch. Works with Thermal Dynamics cpc tooEsab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Not sure if it comes with the pendant. One website says it does, another says it doesnt. Part number 088123.I picked up the supplies to make my own CPC plug but I can salvage the pendant I guess if it comes with it for parts instead.
Last edited by BrooklynBravest; 02-17-2019 at 08:48 AM.www.FirehouseFabricators.comZachLincoln 210mpLincoln SW200Hypertherm Powermax 45xp2x4 CNC Plasma Table.
Reply:Powermax 45xp part number 088123 comes with a machine torch, a hand torch, CPC port installed and a remote pendant. Any questions about Hypertherm part numbers can quickly be answered by a call or email to Hypertherm customer service or tech service! If you have questions about wiring to the CPC port I'll be happy to help out. [email protected] Jim Colt
Originally Posted by jimcolt
Powermax 45xp part number 088123 comes with a machine torch, a hand torch, CPC port installed and a remote pendant. Any questions about Hypertherm part numbers can quickly be answered by a call or email to Hypertherm customer service or tech service! If you have questions about wiring to the CPC port I'll be happy to help out. [email protected] Jim Colt |
