Straight edge cut offset
发表于 2021-9-1 23:15:21 | 显示全部楼层 |阅读模式
What is the offset to be figured when cutting 3/16 with a straight edge on the 45xp?  This is with the standard consumable, not the fine cut. Thanks Sent from my iPhone using Tapatalk Pro
Reply:Make a cut then measure off the strait edge.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:I just measured a set of hand torch consumables in my shop. The edge of the nozzle orifice to the edge of the shield (which is designed to drag along a straight edge or template) measures .200".   Keep in mind if you cut slowly the kerf will get wider, cut fast and it will get narrower. Use .200" offset and you will get pretty close for hand cutting. Before you pay someone to cut 26 stencils you may want to experiment a bit with your technique to see how much offset you will get.   Jim Colt
Thanks, I thought someone might know before I did this....going to get some stencils CNC cut, and wanted it to be preciseSent from my iPhone using Tapatalk Pro
Thanks, I did play with it today, and got .1875Sent from my iPhone using Tapatalk Pro
Got a couple of stencils made to cut these ovals  from flat stock.  The  1875 offset worked good, maybe just shy too big,  will probably try 1600 next time
GMT+8, 2025-12-19 19:21 , Processed in 0.086838 second(s), 18 queries .
