Powermax 45 question can cpc port be added later ? Is there a model for 230V 3 phase
发表于 2021-9-1 23:15:20 | 显示全部楼层 |阅读模式
Considering buying a powermax 45.I dont need a cpc port right away, but who knows in the future.Can the cpc port be added later if i need it ?I guess these are the two models to choose fromStandard power supply230 V CE/CCC 088130  Power supply with CPC port and voltage divider 230 V CE/CCC088131The 400V 3 phase models, can they operate at 230V 3 phase ?
Reply:Yes, a CPC / voltage divider harness (part number 428653) can be easily added at any time.  The amperage draw is relatively low with the 45xp, so you can run it off a single leg of 3 phase power between 200 and 240 volts.  Jim Colt
GMT+8, 2025-12-19 19:22 , Processed in 0.091849 second(s), 18 queries .
