powermax 1000 power
发表于 2021-9-1 23:15:19 | 显示全部楼层 |阅读模式
is there an advantage of using 208 3 phase over 220 single phase to power a powermax 100 plasma cutter? i have both available .thanksr brintle
Reply:Cut quality , cut speed and cut thickness are all the same at different input power levels. Duty cycle is slightly higher when operating on higher single phase as well as 3 phase input voltage. Jim Colt
GMT+8, 2025-12-19 19:23 , Processed in 0.092105 second(s), 18 queries .
