Wire feeder and motor $15
发表于 2021-9-1 23:15:19 | 显示全部楼层 |阅读模式
Found new wire feeder for Harbor freight welders low costhttps://m.aliexpress.com/item/400040...Q1574872570511DaveHF 170 welderHF 4x6 band sawSouth Bend 9NMillB&D mag drillVictor torch
Reply:Is that motor stronger than the original motor?The feed motor in my HF MIG-180 seems designed for the original 6 ft stinger but the prior owner installed a 10 ft stinger. I generally set this welder on the floor to reduce the number of curves between the machine and the gun. This feeds smoother than with the welder elbow-high and tilted upward. A stronger feed motor would be a noticeable upgrade.HF MIG-180 with all the mods.Grizzly H8153 Stick/Tig Pulse 130/160.Wards PowrKraft AC-230. Stick & carbon arc.
Reply:I do not know.This site has other heavy duty wire feeders. Dave
GMT+8, 2025-12-19 19:22 , Processed in 0.092190 second(s), 18 queries .
