Plasma cutter 62204/ 64808 ground cable
发表于 2021-9-1 23:15:19 | 显示全部楼层 |阅读模式
So a friend asked me to replace the ground cable on that  machine, anyone know how it is connected on the inside the unit ? just a lug or is it wired into a board ? Wire is only 10'  8 AWG and very stiff, he wants it a little longer and, more flexible…..any thoughts ?Thanks in advance.
Reply:Its bolted to the PCBwww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Thanks for the reply, I took off the cover and see where it is located. Seems easy enough to modify, I'm thinking of putting a panel dinseconnector on the front panel. Also I notice that when adjusting the max amp,led display only reads 33 amps...is that a problem or normal for a 40 amp machine.
Reply:it should read whatever the machine is rated for.is it a dual voltage unit?i would put a amp clamp on it and compare readings.it's possible the readout is not calibrated very well.
GMT+8, 2025-12-19 19:21 , Processed in 0.080602 second(s), 18 queries .
