I need to do a little work on car floor pans and a few spot welds on various sheet metal parts. This was recommended to me. Has anyone tried it?https://www.harborfreight.com/air-pu...tool-1110.html
Reply:A friend of mine uses one on aluminum fly rod cases every day and he love it.Sent from my XT1635-01 using TapatalkLincoln 175Monkey Wards 230v. Stick
Reply:Thanks! I called the local store today and they're holding one for me. These floor pans are in a Jeep and will be undecoated and sealed over so the seam won't be that visible.
Reply:got one yesterday .works fine but trigger plunger was leaking until i cycled it a dozen or so times.also,the oring on the oil screw was damaged.
Reply:I used one just like it on this Ford.Pretty sure I got it at HF years ago, works perfect. https://weldingweb.com/vbb/showthrea...irs&highlight=Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Originally Posted by Beeker
Great job on that thread! Yeah, I would NOT want to drill all those holes, the punch works much, MUCH faster.
Reply:yes,easy to use and very smooth on both the punch and flanging action.
Reply:I swapped it out today after checking o-ring on the new tool at the store. Tried it out at home and it works great. I add to the Mechanic's Park section as I do the floor pans
Reply:Well I finally got a reply from HF customer service and they said no o-rings are available and return it to the store. Glad I already did and now the one I have one that works very well. Still happy.
