Mig Max 215
发表于 2021-9-1 23:15:16 | 显示全部楼层 |阅读模式
when using c25 is the gas flow  supposed to shut off immediately after you release the trigger or should it flow for a second or two before shutting off.Thankscandyman
Reply:Most of the smaller machines have a couple second post flow now days. It's designed for those who weld stainless. Nothing hurt on the other processes except a few cents worth of gas out of every tank. Also if your burn back isn't turned up more than needed, Post flow can help keep the wire ball to a minimum.Thermal Arc 320SP ( Lorch )Cobra PythonsThermal Arc 300 AC/DC  ( Sanrex )ESAB 301i AC/DC  ( Lorch )Thermal Arc 161STL  ( WTL )Thermal Arc 190S  ( Sanrex )Cut Master 82, 42. Cut45 ( WTL )Victor Gas Apps.Boxes and boxes of welding crap.
GMT+8, 2025-12-19 19:27 , Processed in 0.072180 second(s), 18 queries .
