Harbor Freight's cheapest grinder can be modified to be a great tungsten sharpener
发表于 2021-9-1 23:15:16 | 显示全部楼层 |阅读模式
After not being able to find my bench grinder I've had in storage (I moved to a different state and it's been there for 2 years), and after getting a new welder, I decided to get a new bench grinder. After doing some research, I purchased Harbor Freight's cheapest 3" grinder and a 3" 150 grit diamond wheel off Amazon and the results have been good to say the least! I made a little video a couple months ago, and I've used it a lot so far. Honestly, this grinder probably isn't powerful enough to do much more than grind tungsten, but its quiet, small, and dirt cheap!
Reply:Excellent! I've seen those grinders before. Several years ago I bought a variable speed 6" bench grinder for sharpening knives. I use the fine wheel on one side. I bought a Razor Sharp Edge Making System from Woodvcraft based on a recommendation from a local knifemaker. I use the slotted paper wheel out of the kit for polishing edges. I don't do too much with the fine stone wheel because even it being "fine" on a low speed grinder it can still take off a lot of metal on a blade quickly. The paper wheel is another story - it is a blessing for getting sharp edges as long as the blades are formed properly and aren't overly dull (if they are they need some stone work to bring the edge back before buffing on the paper wheel). For the purpose of sharpening tungsten the diamond wheel probably is a fantastic option. In fact, I would imagine the paper wheel would separate with the point of the tungsten. It is meant for blade edges. It is made out of layers of cardboard paper so a flat or curved blade is fine, a point - not so much. I'd be interested to try it, though. Just FYI - your diamond wheel isn't spinning true. When you spin it by hand you can see the wobble clearly in the video. The way you are sharpening the tungsten off the table (table on the grinder) it might not matter. I suspect that is also what is causing the grinder to walk across the desk - the vibration from the untrue wheels.
Reply:Im looking for something like that for drill bits. I use 5/8 and 3/4 bits in my projects. I wonder if that wheel is too narrow, Your thought?
GMT+8, 2025-12-19 19:23 , Processed in 0.101394 second(s), 18 queries .
