Roughneck 1e
发表于 2021-9-1 23:15:15 | 显示全部楼层 |阅读模式
Older roughneck 1E every thing works as it should except the 220 outlet has one leg at 125v (goes into rotor) and the one coming from the 120 outlet has 118v. any thoughts. Checked all the normal things, I don't understand why the one leg is higher than the rest.Thanks in advance
Reply:If you asked an electrical engineer about how that transformer on the pole splits the high voltage (like over seven thousand volts) into two low voltage lines, out of phase with each other,,,he would go on for a half an hour, then finally tell you that the two voltages being that close to 120 is good!!
Reply:My Miller Roughneck 1E has a single duplex outlet on its face for 115VAC (nominal).  I've never seen one with a higher voltage option for generator output.Last edited by Denis G; 03-31-2021 at 06:48 AM.
Reply:Thanks for the response, I will have to tear into this thing. Any thoughts is appreciated. Did miller make a service manual for these things Have one for the trailblazer handy to have around.
Reply:I have a Roughneck 1 Technical Manual effective with SN R377879.  PM me an email address and I can send it to you.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:PM sent
Reply:email sent Wednesday. Check your Junk Mail.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-19 19:23 , Processed in 0.089315 second(s), 18 queries .
