Help diagnosing 305D
发表于 2021-9-1 23:15:10 | 显示全部楼层 |阅读模式
305D runs good, 3500 hours, no generator or welding power. What are the possible causes? I don't know Lincoln at all so I was hoping to get some help from the pros. Thanks guys!
Reply:Can we start with a Code# off the faceplate?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Not my machine yet. Trying to decide if I should get involved in fixing it
Reply:PM me an email address and I'll send you the Service Manual I have for the Code #s it covers and you can look it over to help you decide if you want to tackle it.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
Reply:Sir I hate to jump in .I to have the same problem however I own this one. How do I get the code?is there a sequence in access to generate code or does it just pop up. Any help would be awesome. Jon
Reply:The Code# is punched/printed on the unit face plate similar to the unit Serial Number.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
GMT+8, 2025-12-19 19:21 , Processed in 0.071722 second(s), 18 queries .
