Lincoln Pro MiG 140 Dead
发表于 2021-9-1 23:15:10 | 显示全部楼层 |阅读模式
Hi,I’m new and know little about what I am doing with a mig welder I bought on a whim some years ago at Lowe’sSn M3980611173was working well but then sputtering and died.trigger is good wire feeds easilyflux core .035no gasNo spark at all now.connections are tight.and perhaps moist critically right in the middle of a honey do project.anything would be greatly appreciated CrobarLast edited by Crobar; 03-27-2021 at 04:32 PM.
Reply:This will sound dumb, but I've seen the knobs on those get turned slightly off from the click point. Still feeds wire but no weld.If yours has continuous dials, then that doesn't apply...But, make sure your "ground clamp" is clamped on a bare ground down spot.If good contact is not made, no weld.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Good clean contact point just a couple inches from weld point.new ground clamp.will check dials for good positioning as I do believe it is something odd like that.thanks for your response Crobar
Reply:No gostill no sparkmaybe I need to test components?Don’t know which is most likely to die first.
Reply:If you feel up to it. Below is something to get you started. See if you have power to the control board.
I Fix Stuffwww.millerserviceparts.comwww.lincolnwelderrepairparts.com
Reply:Find a volt meter and connect it to the polarity studs. pull gun trigger. see if you have voltage at this point and your wire feeds. If so, short the gun tip to the work clamp while meter is still connected to the studs. pull trigger, if voltage does not change the miggun is open. If you don't want to take a chance on damaging the tip, feed out 6 inches of wire and put work clamp on the end. if gun good the wire will turn red.If you do not have voltage at the polarity studs you have a problem inside the welder case.
GMT+8, 2025-12-19 19:25 , Processed in 0.066055 second(s), 18 queries .
