What year SA 200 ??
发表于 2021-9-1 23:15:10 | 显示全部楼层 |阅读模式
What year is this?What would you offer?They want 800 / BOSupposedly ran when parked ... LoL!!
Last edited by John T; 08-15-2020 at 08:32 PM.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:SN looks like A-461872. Can you confirm? If that is the case - it is a 1963. See here:https://m.lincolnelectric.com/en-us/support/Documents/Age_of_Machine.pdfIs that an AC outlet I see under the middle of the setting dials? I thought those were all DC machines - no way to easily get 120vAC for other tools etc. Maybe that was an option on some? Or a power inverter off the starter battery? Though, back in the early '60s I don't think inverter technology was around...Last edited by FlyFishn; 08-15-2020 at 09:46 PM.
Reply:Looks like a rare red/blue face machine which apparently were made for the military and the engine is balanced. It's a very desirable machine if you can get it running and worth a few thousand bucks at least. Price isn't out of line and some people would be all over that. If it turns over probably just needs some mag and/or carb work. Plug in is 110 volt DC.
Reply:Great description!Might be stuck?!?Simple to work on. Easy access to everything.If it's worth your time...Personally, I find some kind of Zen messing with old machinery.Miller Dynasty 350Miller XMT 304
Reply:I’d offer $500 , worth that much in parts
Reply:Being what it is, you'd want to try and fix it. Especially if it's not stuck, it's worth the asking price. My guess is the seller doesn't know what he has and that's great for the buyer. Anything less than the asking price is a good deal. If it is stuck or requires more work than you want to put into it, it wouldn't be hard to sell to someone else if advertised in the right place... like a welding forum. The factory red/blue face plate adds to the value over a standard red face or red/blue clone. I'd offer $600 so I wouldn't insult the seller with too low ball an offer. For comparison there is a non running red/blue face plate machine that needs a new engine listed for $2500 in the buy/sell forum.Last edited by Welder Dave; 08-16-2020 at 12:55 PM.
Reply:I’m sure somebody got a good deal.  I’d like to have one someday to tinker on. But at this point in time I’ve got too many irons in the fire. .
Reply:That was definitely a Redface.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:The split front panel means it can’t be newer than 1967. Sometime in that year they went to the stamped one piece front panel on the SA200 Sent from my iPhone using TapatalkSteveMiller Dialarc 250 (1990)Miller Maxstar 140 STR (2003)Lincoln SA200 Redface Pipeliner (1966)Lincoln MP210 (2015)Victor and MECO torches
Reply:here's what the faceplate code: 4999 should look like. stumpfweldingsupplies.com/product-page/sa-200-5-position-redface-nameplateLast edited by BYW200; 08-22-2020 at 12:59 PM.SA 200s : 1944 1945 1963 1965 1969 1981 SA 250 D3.152 DC only2004 Ranger 10,000Lincoln Pro Mig 135Miller Load BankHobart GPB 258 PipelinerHobart GPB 261 MainlinerHobart Airforce 250Everlast PA 200st
Reply:I ended up buying this machine paid 600$ for it.  Engine was locked up solid.currently restoring the entire machine engine being bored out sadly it was already .020”
Reply:This machine is now mine....I thought based by my code that it wasn’t a blue dial but it does infact have a blue dial face plate
Reply:I'd guess the engine could be bored again. Very desirable welder.
yes I am in CT. Engine is torn down completely at the machine shop currently being bored out. I opted to remove the home built POS trailer it was on. Just had all new metal bent up for the battery box/radiator support. She’s gonna take awhile but it will be pristine when I’m done I’m a fanatic about details
Reply:So what year is that KW? Pretty sharp.
Reply:1983 with a 1693 cat in it
GMT+8, 2025-12-19 19:24 , Processed in 0.098458 second(s), 18 queries .
