What are the advantages of laser welding machine compared with argon arc weld...
管理员
Rank: 9Rank: 9Rank: 9
发表于 2021-6-11 14:45:13 | 显示全部楼层 |阅读模式
图文
图文封面:
Hand held laser welding machine is a particularly popular automatic welding equipment in recent years. For many manufacturers still using argon arc welding machine, special equipment for laser welding is a new thing and new technology. If you want to use laser welding machine technology but do not know the specific situation, then today, general electric power company will explain to you what are the main advantages of laser welding machine, To solve the confusion for the manufacturers still struggling.
The appearance of the products produced by laser welding machine is more beautiful
First, the beam quality of the products welded is stable, the welding is firm, the welding seam is smooth and beautiful, and the area of thermal adverse impact is small during welding, so the welded workpiece is basically free of deformation and no welding scar, and no secondary grinding process is needed. For the enterprise manufacturer, it is actually saving time, improving the working efficiency and reducing the labor cost.
Laser welding machine has faster welding speed and higher production efficiency
Laser welding speed is faster, 5-10 times faster than traditional welding, deep penetration, high welding quality rate of different materials. And equipped with special cold water equipment, so as to ensure continuous operation for 24 hours.
Energy saving, consumption reduction, safety and environmental protection
The energy saving and consumption reduction of laser welding are more green and safe, and the traditional argon arc welding machine will cause a lot of welding dust and residue, which is harmful to the environment, while the hand-held laser welding machine has a relatively small impact on the natural environment.
Simple and easy to learn ordinary people can operate without certificate, help enterprises improve efficiency, but also save the cost of employing
Taking the argon arc welding machine as an example, the welder who needs to be mature and stable must hold the welder certificate to work. The manual laser welding machine can only be used by ordinary operators. The cost of an electric welder with mature and stable welder certificate is higher than that of ordinary operators, and the operation of the hand-held laser welding machine is simple, Without experience, no teacher Fu can weld beautiful products. The welding speed is faster than that of traditional welding process by 5-10 times, and a laser welding machine equipment can save at least 2 welders a year.
Less loss, long life
The consumables are less and the service life is long, which can meet the needs of long-term welding. The general electric hand-held laser welding machine basically does not need the cost of consumables. The pump source has a life of 100000 hours, and it is basically maintenance free.
Hand held laser welding equipment can be used in hardware products, sheet metal, chassis, water tank, distribution box, cabinet, kitchen and bathroom, furniture and household appliances, stainless steel door and window guardrail, advertising signs, process products, battery components, steel furniture, shelves and other major fields, as well as seam welding, fillet welding, butt welding, inner fillet welding, vertical welding, etc. In material, the laser welding machine can be used for welding aluminum, iron, stainless steel, copper and other metal sheets of the same material. As well as aluminum copper, stainless steel, copper and other mixed materials welding, covering the field is far more than the traditional welding method. These main advantages are not possessed by traditional welding
Guangdong Pudian Automation Technology Co., Ltd. is a professional manufacturer of welding equipment. For 16 years, it has focused on R & D and sales of spot welding machine, laser welding machine, non-standard automatic welding machine, welding robot and other welding equipment. Pudian welding machine focuses on the field of metal welding, saving energy and reducing consumption, improving welding quality and improving welding efficiency, Reducing the cost of welding is our fundamental service to customers.
Free proofing hotline: +86-1353885280
Address: Zone B, 1st floor, C-1, No. 6, industrial North Road, industrial park, Songshan Lake high tech Industrial Development Zone, Dongguan, Guangdong Province, Tel:+86-769-81767569
本帖子中包含更多资源
您需要 登录 才可以下载或查看,没有帐号?立即注册
x
GMT+8, 2025-12-17 07:07 , Processed in 0.085078 second(s), 22 queries .
