Lincoln Mig-Pak 15 package
发表于 2021-9-1 23:15:05 | 显示全部楼层 |阅读模式
Hello all.Back in early 2,000's while restoring an old car, I purchased a Lincoln Mig-Pak 15 welder, cart, gas bottle and about 30 lbs or so of welding wire.After a small amount of use, I discovered my talents are in the mechanical side of auto restoration and not the sheet-metal side. In the interest of speed and protecting as much of the original sheet metal as possible, I ended up hiring out the sheet metal welding. ( so, the welder probably has less that 30 hours of use since new)I held onto the welder thinking after the car was restored, I was going to find someone to teach me proper technique etc for the next time around.  I never did. so, the welder has been sitting in my  garage taking up space and I am now going through my garage to totally reorganize.With all that said, I am trying to determine the welder's current value.  Please advise on what I should be able to get for it.Lincoln Mig-Pak 15 (Lite usage)Liner just replaced and testedadditional spare linerHarbor Freight welding cartwelding-gas bottle with regulator & hose (40lb empty-- plastic lens covers missing from regulator)extra gun nozzle and a few tipsunopened 10lb spool of .030opened spool of flux core.opened spool of .023 (likely worthless, it appears to have collected a lot of dust/dirt)
Reply:First, include your location. That affects market price and if any members close by.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
GMT+8, 2025-12-19 19:40 , Processed in 0.090599 second(s), 18 queries .
