Square wave 200
发表于 2021-9-1 23:15:05 | 显示全部楼层 |阅读模式
I'm a welding g hobbyist. I use this machine for tig but have lately started doing some projects with the stick function. Now I have some questions about polarity and the machines ability I need cleared up.I'm pretty sure when I hook my stick leads up the way Lincoln wants you to, the machine runs dcep.Is it acceptable to swap those leads and run dcen?Also if I wanted to run ac stick could I leave the machine in tig mode and use my foot pedal? Is any of this hard on the machine?Also has anyone wired in an adjustable timer to control post flow? If someone already had a diagram and timer selected that would save me the hassle of doing it myself.
GMT+8, 2025-12-19 19:40 , Processed in 0.071644 second(s), 18 queries .
