Let's see your tool boxes.
发表于 2021-9-1 23:15:02 | 显示全部楼层 |阅读模式
I will start. I made the shelf between the boxes.
I want to see how you guys roll. Sent from my iPhone using Tapatalk
Reply:I called Strap-On. They wanted 8 grand for equal real estate so I grabbed some  1x2 , made a frame and went out to the woodshed for a lil Nectandra megapotamica ;-) I did have to buy the 100 lb sliders
24  x 48
Reply:Then there's this stuff. Mostly hardware, drilling,welding, cutting,plasma consumables, gun stuff,knife stuff, electric etc.
Originally Posted by VPT
Looks like WI fish pics?
Reply:Nice!I take it a you like bananas? lol12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
24  x 48
...zap!
I am not completely insane..Some parts are missing
Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Blown FE 'stanger ? Cool stuff.
SnapOn(s) in above pics.
Best for the money: the International side cabinet from Princess Auto. (Photo above).   Surprisingly good quality. My fave:  My first Craftsman roll cab I bought when I was 18.   Sold it to my best friend ages ago and still going strong after 48 years.
Terry
Ingenious. nice!!, Hoist. Sent from my iPhone using Tapatalk
Reply:Unorganized chaos at its finest. Thankfully the tools in the drawers are organized.
Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Another one.
Originally Posted by MetalMan23
I like those "AA" batteries
Reply:Snap On top from the 60's, bottom from the 70's, middle from the 80's.  Blue Point from the 90's. Side box from last year. Plus many metal storage cabinets mainly for my machinist tooling.
Reply:Yep,The hoist is a 1 ton davit off ebay or amazon or someplace like that. Was 1000 lbs at max extension. I then added a smaller inner tube with roller on end and it works in 2 positions. Then added 500 lb electric hoist from harbor freight and put a hook point for double line lifting on the original inner tube so that it couldn't be used with the new roller end tube extended. The top is 1/4" thick with 2" 14 ga square tubes under it, the spot where the hoist mounts there is extra tubing criss crossing it as well as 1/2" thick plate padding to make sure none of the bolts would have an easy time ripping through just 1/4"The outriggers are just tube inside of tube, and I painted one end red and then painted yellow up to a point where there was still enough left inside to be strong. Good visual indicator of when they are at full extension and was easier than figuring out some mechanical limit device.Last edited by Pugs_; 05-02-2017 at 01:06 PM.
Reply:I'm diggin' that mini crane Pugz. Brilliant !
Reply:I have to laugh that most here like it and I had posted it on a garage forum  back when I originally made it and the safety nazi's came out of the wood work telling me how I was going to kill myself with it, even though I fully tested it throughout its full range with and with out the outriggers down and kinda know what I'm doing. Glad I'm not on that forum anymore...
Reply:Hand tools go in the rollaway. Electric tools, and supplies go in the cabinets.
Don’t pay any attention to meI’m just a hobbyist!
CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST
3 SA-200sVantage 400
Reply:Cep. Who makes that box ? Thats the layout I prefer metric one side-gringo on the other
Reply:CEP  if you ever decide to start welding for a living your pretty well prepared.
lol, everyone thinks its electric. But they are just the counterweights so it doesnt tip over when using hoist. I got the solid rounds from scrap yard and needed some way to easily pick them up and set into box frame (on its side) so I made the little pucks with 1/2-13 holes in them. Once they were on I thought it kinda looked like a battery and figured if I dressed them up a little it would look nicer than just painting them solid color same as the frame. And they are not AA, I marked them 500LB
I wound up removing one of them awhile ago and its still plenty stable, but moves around alot easier. They are 500 lbs each and the hoist at max reach just reaches over top of where they are and is rated to 500 lbs at the radius. With both weights in I could pick 500 lbs up at the side without the outriggers down, now with one weight the outrigger needs to be down.Painting the weights and the box frame in background, upside down.
Back side of box with hooks for rigging stuff and electric reel (reversed the plugs so I could pull it out and plug into wall.
24  x 48Attachment 1657761 Attachment 1657771Attachment 1657781
Not nearly as impressive as my work box, or others on here. Here's the last of my boxes, in my man cave. No welder at home. I just use my welder at work if need to. Sent from my iPhone using Tapatalk
Reply:I wish they were all blue. I like to be color coordinated, seems my welder choices are all different colors so had to give up on that idea.
ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:I saw some nice boxes at Home Depot last week.  Milwaukee and some other brands.  Looked like they were priced fairly decent as well.Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
Originally Posted by Lis2323
Reply:Let's see your tool boxes.
Originally Posted by zapster
Attachment 1658001Attachment 1658011Attachment 1658021...zap!
Reply:Gotta Love tools!!!
Sent from my XT1585 using Tapatalk
-DoogieMiller 350PMiller Trailblazer 325 EFI w/ Excel PowerLincoln LN25 suitcase welderXMT 304/22a feederMiller Syncrowave 350LXMiller EconotigHobart Handler 140(2) Uni-Hydro 42-14Hypertherm 65 plasmaWEBB Gap bed lathe
Reply:Well Mr. Turner, I changed me mind. Is this boxy enough then?
It ... looks ... "old here", or something.
City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:The second string home box, used, low budget, small footprint, needs to be reorganized like everything...
Reply:Here's my harbor freight box!
- Christian M.C3 Welding & Fabrication - CNC Plasma Cutting-Mobile Welding-Custom welding and fabwww.c3welding.com
Reply:Bumpty bump! bump!It’s been awhile. Let’s see some more tool boxes. Sent from my iPhone using Tapatalk
Reply:Home built junk
Reply:Prototype that began as a shipping crate.
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~At work.
Originally Posted by OMB
That doesn't look like a toolbox, that is more like a lunchbox.
GMT+8, 2025-12-19 19:40 , Processed in 0.097973 second(s), 18 queries .
