Champion 16 serial number
发表于 2021-9-1 23:14:59 | 显示全部楼层 |阅读模式
I have a champion 16 generator welder. The prior owner told me he bought it new in 1998. Im having a hard time finding the manuals for it because they made tons of these and my serial number is illegible. I see theres a tag on the front of the machine which at some point gave the model serial and spec, but its so faded that i can barely make out anything it says. Is there anywhere else on this machine with my serial number?The reason i want the manual is because it doesnt make enough amperage. I have the thing maxed out and i can barely keep an arc going with a 1/8 7018 rod. It probably needs brushes but i wouldnt know where or what to order because i cant identify this damn thing
Reply:Okay upon further inspection i found another tag under the panels. Model: champion 16Spec: sp7116a-001Serial: 295wr03434The brushes and slip rings actually look surprisingly good. Not that it matters because i cant find brushes anywhere for thismachine. I dont really see any hobart parts online. Im getting 123 volts at the regular outlet. I adjusted the engine speed to 3600 rpm because it was onlygetting up to 3400 rpm. Im not sure of that would have made a difference. I havent tested it with a weld yet i was just tinkering with it.
Reply:Call Hobart welders. Might be able to tell you something with the engine serial numbers.Also there might be a serial number sticker hidden inside some where. Just ask Hobart.
Reply:Think this is the gray color Hobart champ 16, these seem to be very similar to the Miller bobcats of those years.
Reply:Okay so i was able to order a manual for my exact machine. According to the manual its a 1995 model year. Under troubleshooting, good receptacle voltage but low welding power points to a bad reactor. The reactor part number according to this book is 493990-1. I cant find it anywhere online. I emailed bills welder repair but havent got a reply yet.
GMT+8, 2025-12-19 19:40 , Processed in 0.070422 second(s), 18 queries .
