Given the choice to purchase either one of these welders for the same price, which one would you choose? The Cybertig is bigger, heavier, has a lot more power, has all the manually adjustable features, but it's an old model and parts availability might be getting questionable and will only get worse. The EZ-TIG is a current model, smaller and lighter, but has less power and all the variable features are preprogrammed and not manually adjustable. What do y'all think?
Reply:What's the serial number on the Cybertig? Wondering if it crosses over to a Miller machine like a Syncrowave 250. The EZ-Tig is the same as a Miller but only does Tig.
Reply:The picture isn't clear, but the layout of the cybertig looks very close to the layout of their TIGWave 250 AC/DC.Check out my bench vise website: http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:The serial number of the Cybertig is: KK146627.I would prefer to have the one with more power and manually adjustable features, but is it really advisable to buy a 20-year old machine? It may work now but what when something goes bad?As for the EZ-TIG, how limiting is it to have all the adjustments preprogrammed like that? Obviously I'm not real familiar with TIG welding.Hobart Ironman 230Hobart AirForce 40iHobart EZ-TIG 165i
Reply:It really depends on what you want to do with it, the Cybertig is a hell of a machine, it a Miller and I believe around a 2000 model, 300 amps and a monster of a machine and requires substantial single phase power. I would not worry of it breaking down if it works when you buy it and plenty of parts still available. The econotig is small and with that small power and reduced duty cycle, don't plan on any aluminum or steel over 1/8 thick. But if you want something that does not require a 100amp breaker and 2 guage wire feeding it with a smaller footprint then they are solid welders.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:I have an EZ tig, it's identical to a miller diversion, the torch has miller on it. The miller cost 800 to 1000 more. I don't see much use for over 200 amps on tig machine with an air cooled torch. At 200 amps a 17 torch will heat up real fast. I have two tig machines, a 200 amp and the hobart EZ 165. I use the EZ165 the most because I get more weld time before the torch heats up. I like simple the best. All the wavy gravy functions on a tig machines are not necessary 90 percent of the time. I have never been limited in any way with the Hobart 165 welding up to 1\4 steel or aluminum. 1\4 aluminum is a little trickier than steel but can be done.
Reply:The Cybertig is a 1999 Syncrowave 250. Serial number comes up on Miller site. That's the machine to buy.https://www.millerwelds.com/support/manuals-and-partshttps://www.millerwelds.com/files/ow.../O353T_MIL.pdf
Reply:Aluminum requires more amps than steel. 165 isn't enough for 1/4" aluminum. |
