Spool Runner 200 vs. DP3545-20 (spool guns)
发表于 2021-9-1 23:14:57 | 显示全部楼层 |阅读模式
When the new Hobart Ironman 240 was released to replace the Ironman 230, Hobart also released a new spool gun that is noted on its specs as for the Ironman 240. Does anyone know if the Spool runner 200 will work with the Ironman 230?I called Hobart but got a non-definitive answer that the voltage for the spool gun drive motor *might* be different between the 240 and the 230, but I can't confirm that anywhere.Beuford
GMT+8, 2025-12-19 19:42 , Processed in 0.093204 second(s), 18 queries .
