Used Ironman 230 what’s it worth?
发表于 2021-9-1 23:14:57 | 显示全部楼层 |阅读模式
I found an IM230 supposedly little use (stated only used three times
). It’s a 2 hour drive, he’s asking $950, hoping to get it for $850, what do you think is reasonable? I know the 230 is now discontinued and the 240 is out. Can this machine run .023 wire if I need to at some point?Thanks guys!
Reply:Definitely grab it!  You'll make your money back quick on it I think.
GMT+8, 2025-12-19 19:47 , Processed in 0.069469 second(s), 18 queries .
