Hobart 10000 cannot turn heat down
发表于 2021-9-1 23:14:55 | 显示全部楼层 |阅读模式
My Hobart Chanpion 10000 runs great, but I cannot turn the heat down. She's running HOT and then gets Hotter.  I've been welding for over 40 years and never had this problem.
Reply:Well10,000 Amps is an awful lot. What did you expect?Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Probably a bad rheostat or something similar. Hopefully someone with repair experience comes along. You might be able to download a manual with your serial number on the Hobart and/or Miller site with a troubleshooting guide.
Reply:Thanks for nothing.
Originally Posted by Bugboy 30122
Thanks for nothing.
Originally Posted by John T
Nothing is nothing. Everything is something. Sometimes you need to peel back the onion to reveal its sweet beauty.
GMT+8, 2025-12-19 19:42 , Processed in 0.096560 second(s), 18 queries .
