Thermal arc 95S repair question
发表于 2021-9-1 23:14:54 | 显示全部楼层 |阅读模式
I was misinformed of the operation specs of the TA 95S welder.I bought this machine used but working perfect/tig and stick, but no operating manual.I was told that it could be used 110/120 volt or 220 with adaptor.But come to find out it is a 20 amp adaptor plug not 220 volt input.Well my big mistake for not taking the time to look closer to the warning. My bad! I pluged the TA 95S adaptor plug to a step up transformer to 220 volts.As soon as I pluged it in, I heard a pop, like a small fire cracker sound. I unpluged it quickly. I am sure it will not work now.I pulled the cover off and noticed a odd smell and I only noticed a black burnt area on/under a flat round looking electronic part # W-LR201My question? does anyone know if I really messed up in cost repair by applying 220 volts to my welder instead of 110/120 volt machine. Or may be a simple fix?I couldn't find a fuse on the machine. I would have thought all welders come with fuses, unless I missed the location of the fuse.Does anyone have any idea of a repair cost on my TA 95S ? or know someone that can answer or fix my welder. I can solder and use a test meter but not much electronic experience. I appreciate any advice.THE OLDER I GET! THE  SMARTER MY DAD WAS!Thermal Arc 185 inverter Tig welderABITIG 26  tig torchLotus foot pedalLincoln 225 stick welderClark 185SG Mig spoolgunwelderVictor torch/regulatorsHF36" shear,bender,roller.
Reply:I believe that is a current sensing resistor.Feel for you - I've seen the "magic smoke" come from stuff I own before too.
Dave J.
Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thermal does not fix them under warranty. Just replaces them.They are little great unit's but throw away type of machine Does not mean that can't be fixed though.. I just got that info from the thermal rep, when the machines first came out in the states. Was tested in Australia before here, and passed with flying colors. I think only one machine had some issues out of many many units..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:I appreciate the info. I did just send a message to Thermal arc.. I just hope it won't cost the price I paid to fix it. It seems to me a fuse should have blown first, but it was my stupid mistake for not doing more research first. It is a simple machine and worked perfect for the intended use. I feel like your
icon when I did it. Thank you. fingers crossed! I hope it's just the current sensor!
Reply:Even without a manual, there should be a specification sticker on the unit that indicates the input voltage.  This is a good way to confirm other "things" people tell you about the unit's performance as well.From the part number, looks like you blew a current sensing resistor??Last edited by lugweld; 04-24-2013 at 08:18 AM.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 19:40 , Processed in 0.068350 second(s), 18 queries .
