Help finding parts
发表于 2021-9-1 23:14:53 | 显示全部楼层 |阅读模式
I have a 110 Schumacher mig welder model #90441.  Long story short, the wire speed dial is broken off flush and I can't adjust wire speed.  Does anyone know where to get a replacement part.  I will need the whole part.  Just the knob will not fix it.  Thanks in advance for any help.
Reply:We had a Clarke wire welder with the same problem, the shaft was plastic i heated an old screwdriver blade and pushed it into the shaft to make a slot in it. Just used a screwdriver to adjust it after it cooled off until the welder finally died.
GMT+8, 2025-12-19 19:34 , Processed in 0.092105 second(s), 18 queries .
