For a small project i am looking for the following:5x ring, 3" outer diameter with 2-1/2" hole5x ring, 3" outer diameter with 3/4" holeParts out of stainless (304 is fine). Thickness anywhere from 1/16 to 1/8th is fine. Please send me a PM with a quote if you can help me out.
Reply:Where are you located?Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table
DIY TIG Torch cooler
Reply:PM sent. I am local to you.
Reply:Parts ordered. Thanks. Thread can be closed.
Reply:Threads only get closed if they go south - which this one doesn't qualify. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110
Save Second Base!
